How can one draw a parabola within Revit?
ro
Message 1 of 14
ro
Is there a way to draw a parabola within Revit, without using Dynamo? "No" is an acceptable solution.
Replies (13)
Message 2 of 14
Tom_Kunsman
At first I was going to suggest using the spline thru points, which would be a bit tiresome as you would need to calculate the points and place a bunch of reference planes. Then I did a quick search and found these two links (one not ADSK forum, sorry)
https://forums.autodesk.com/t5/revit-architecture-forum/parabolic-curve-wall/td-p/7484025
https://forums.augi.com/showthread.php?12962-Parabolic-Curve
Message 3 of 14
Google "How can one draw a parabola within Revit?".  You'll get a half-dozen or more hits of tutorials.
Message 4 of 14
ro
I tried an internet search before starting here.
I can see Dynamo solutions and I can see fragmented, laborious approximations but not how to draw a pure porabola in Revit.
Ultimately it's a formula (any) that is drawn.
Message 6 of 14
ro
Thanks again @barthbradley . I have done that search (I use duckduckgo but tried google for laffs). I can't see any relevant results, hence this forum post.
Message 7 of 14
Use Generic Model Adaptive family, add ref point and set their location using parameters (driven by a parabolic formula), then select the points and create a curve through points.
Message 8 of 14
I'm not following you. I posted above an actual link to a video tutorial showing how to make a parabola in Revit. Is that not satisfactory?
Message 9 of 14
ro
Thanks @barthbradley . When I do that search I see a range of hyperbolic surface but not parabolas. Could be a google issue at my end.
Message 10 of 14
ro
thanks @ToanDN . Sound promising. Will road test this in a couple of hours.
Message 11 of 14
Post a picture of the parabola-shaped construct that you are wanting to model in Revit.
Message 12 of 14
ro
Hi @ToanDN . This isn't too bad but, the resolution is determined by the number of points you create. And the shape is a series of splines. Is that correct?
Message 13 of 14
Tom_Kunsman
Yes, the resolution would be determined by the number of points. The more points the smoother the curve will get.
Message 14 of 14
bogadept
Community Visitor
Community Visitor
Barth, every time I open a thread on the Autodesk forums, I see you making snide remarks under someone's post. You need to save the condescension for your Reddit account and work on your civility.
