How can I turn plaster around the column
I want to turn plaster of the wall around the column how can ı do this? I am adding caps .Thanks..
I achieve this sort of stuff by trimming the walls to overlap the column, then join the column to each wall. It will cut away the overlap Making it appear only plaster is running past.
constantin.stroescu
maybe the following screencast can be helpfull....
https://screencast.autodesk.com/main/details/5a685038-54c0-4603-b844-d5a89421825b
Constantin Stroescu
thank you very much for the answers
hey
sorry but when i open the attached link i cant understand what is going on
thank you
