How can I send Revit model to customer without losing material Image?
Message 1 of 8
This model I sent to my colleagues for Testing visa E-Transmittal Add-in ... but the material still missing !!
So how can I perfectly send the Revit model along with the material image to the customer ?
PS. I don't think manually "sending all the material image files and Customer do the image mapping manually" is a good solution.
Thanks in advance.
Replies (7)
Message 2 of 8
ennujozlagam
@Anonymous hello, is this LINK can help? thanks
Message 3 of 8
That's work on sharing the material but the image is still missing because
the image is located outside the adsklib file.
any other solution?
Message 4 of 8
any other solution?
Message 5 of 8
kmfuhrman
Try using eTransmit. It's available as an add-in to Revit in the Autodesk App Store, or the Autodesk Desktop App. https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2017/EN...
Kimberly Fuhrman, LEED AP BD+C
Freelance Architectural Technologist
Message 6 of 8
Try the e-transmittal already... doesnt work for rendering images...I think it's work only for decal image.
Any other ideas?
Message 7 of 8
kmfuhrman
I understand. In that case, I would have to agree with ennujozlagam's post...if you are sharing the model, you would have to send the the material library with it. You can save the custom materials in a new library, and just send that .adsklib file, but unfortunately, the material is associated with that particular library asset.
Message 8 of 8
kmfuhrman
If it is just a few images files, you can add them to the eTransmit package. Unfortunately, they would still have to be a part of the client's material library to be shown as a rendering material. Could you save your rendering images within the project as views?
