how can I save a project in older versions?
lina_riquelme2201
lina_riquelme2201
I have revit 2025, but i want save it in 2024, due to problems with 2025 version (it closes suddenly) so I have download the older version but it cant open my project. what should I do?
Accepted solutions (3)
RDAOU
@lina_riquelme2201
You can’t back save to older version. Your best bet is to export as IFC … when you link that into 2024 it will generate a .ifc.rvt  file which you can use.
do u have all the updates installed… maybe u can try fix the crashing issue . Check your other post and upload the Journals (See Link Below)
the program closes suddenly - Autodesk Community
handjonathan
Hi @lina_riquelme2201
Thanks a lot for posting your question to the forums!   Has the solution suggested by @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
RSomppi
What is causing the crashes?
Do you get any messages as it is crashing?
Does it happen in all files?
Reinstalling Revit may fixe the crashes.
If not, maybe there is something wrong with the model.
HVAC-Novice
You should resolve the crashing issues. Did you install the latest SP? R2025.4?
https://revitlink.blogspot.com/2017/05/why-is-revit-not-backwards-compatible.html
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
