the program closes suddenly
4 ANTWORTEN 4
Nachricht 1 von 5
lina_riquelme2201
192 Aufrufe, 4 Antworten
the program closes suddenly, out of the blue. I cannot work propperly. it happens every ten minutes approximately. I have 2025 version, what can I do?
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: lina_riquelme2201
@lina_riquelme2201
from the given info, it is hard to know what is causing the crash. You would need to attach the journal file so one may check and help you accordingly. Otherwise, the following may help:
  • First you need to make sure you have the latest updates installed.
  • If you have running firewall or VPN switch them off and feast without them just to check if either is causing the issue
  • make sure you have enough disk spac
  • type %Temp% in the windows search  box and delete all temp files and folders you find therein
  • try to reduce screen resolution to that recommended for revit
Nachricht 3 von 5
RSomppi
When it crashes, make notes as to what you were doing at that time. It may provide a clue or two as to what is causing it.
Nachricht 4 von 5
RDAOU
@lina_riquelme2201
PS: the Journal files can be found in the following folder
  • C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\Autodesk Revit 2025\Journals
replace %username% with with the windows user. And try to post the file straight after Revit crashes
Nachricht 5 von 5
handjonathan
Hi @lina_riquelme2201
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @RDAOU @RSomppi helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
