How can I put these interior timber slats on the interior of my curved roof?
20445393
20445393
I have made some timber slats and have put them on the interior of my walls, I would also like them to be on the interior of my curved roof shown in the photograph.
Does anyone know how I can make these timber slats run along the curved path of my interior roof?
Beams. Use 3D Snapping and Pick Lines Tool.
@barthbradley
Will this work in a horizontal direction as well?
The same way my slats are running in the photo I provided?
Like this?
There are a butt-load of ways to do that. Simplest way would be a 2D Surface Pattern.
If you'd rather have quantifiable geometry, then modeling the individual Planks as a Pattern-Based Curtain Panel would work nicely.
Not a workflow I can teach you in a short reply though. You'll need to research it.  Here's a video tutorial to get you started:
https://www.youtube.com/watch?v=DwLcmdVojFI
"Ah! I see now!" said the blind man as he dropped his hammer and saw.  😎
handjonathan
Hi @20445393
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
