Message 1 of 16
05:59 AM
- Mute
- Permalink
- Report
I need to create a set of stairs with a 3 metre rise and 15 risers each of 200mm. When I try to create these stairs it automatically changes the number of risers to 18 and also changes the height of each riser to 166.7mm.
When i try to change to number of risers back to 15, i get an 'Error - Cannot be Ignored' message:
"Desired Number of Risers is too small. Computed Actual Riser Height is greater than Maximum Riser Height allowed by type."
The stairs that I want to make have been specifically designed to have 15 rises of 200mm. Is there some way I can manually input the riser heights?
