HOW CAN I MAKE RENSTRICT AN ELEMENT DEPENDING ON THE NUMERS OF ELEMENTS CREATED BY AN ARRAY
obranovo
obranovo
Hi to everyone. I would like to get help with this.
I want to renstric an element that it could changes only when a parameter of array is modified.Captura de pantalla 2024-04-15 094332.png so if i created a new number of tower sections  the green element that is the foundation will be  aligned to the new created sections in the array .
Accepted solutions (3)
Simon_Weel
If you need the foundation to go up / down with the amount of elements in the array: constrain it with a dimension calculated by the number of elements in the array and the height of the element.
obranovo
I HAVE BEEN TRYING IT BUT I CANT REACHED IT YET.
Could you especicified more please.
I´ll apreciate it .
mhiserZFHXS
What exactly have you tried? The issue could be any number of things.
RLY_15
Is this a Drafting View with Detailed Elements? A Family? Solutions depend on what you're working with.
For instance, you could do something like this with Global Parameters:
But you would have to change your Tower Section family such that the array is baked into the family instead of arrayed in the project file - for some reason project arrays can't be defined with a parameter. This link explains in detail: https://revitcat.blogspot.com/2019/07/arrays-in-revit-global-parameters.html
Are you saying that you want the foundation gets deeper when the tower gets taller? If so, you just need to associate the foundation depth with the array parameter via a formula.
obranovo
Im working with a family.
Thank you I will try it
