How can I get two gutter segments join?
roedigerF6NSW
roedigerF6NSW
As you can see in the attached picture, I've placed two gutter segments on the fascia but they are not automatically joining and it doesn't seem that pulling them to intersect one another works like it typically does with a sweep. Any solutions?
syman2000
Stretch one of the gutter and then placed it on the other gutter end point. This should auto join the corner. If this doesn't work, check and see if the roof edge is at the same level. If one is off by 1/16" or 1.5mm, it will not join the corner.
Have you tried using the Add/Remove Segment tool?
..or...
