Why is this Rebar Not Shaded?
3 ANTWORTEN 3
Nachricht 1 von 4
BigPicture045
267 Aufrufe, 3 Antworten
The rebar is solid white. I would like it to display as a specified grey.
I've changed the material of the rebar to steel and modified the properties. I would expect this to change the view state in this section. Does rebar have particular rules that do not follow the assigned material?
3 ANTWORTEN 3
Nachricht 2 von 4
blank...
als Antwort auf: BigPicture045
Select it, and in properties:
Nachricht 3 von 4
anze.kumar
Maybe also check how is the Rebar color set in Object Styles:
Nachricht 4 von 4
kostask_oionei
You can display the rebar as grey in shade visual style.
Otherwise you have to change the Surface Pattern in Visibility Graphics.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
