I drew in a structural beam system but it just showing blank in floor plan. When I hover over it
I do see dashed lines.
Detail level is set to fine and structural beams are set to on in vg, but beams (floor joists in the case)
won't show. They do show in section. Why might this be?
Also, how do I rotate the beam system?
Thank you
Solved by BDMackey. Go to Solution.
Solved by ToanDN. Go to Solution.
Thank you
You need to assign a beam type to the system. To rotate, edit the boundary, change Beam direction or draw it in the angle you want. Also, you may need to lower the view range if the beam system is at or lower than the level.
The beam system is a rule based element that models true beams. Check your View Range to make sure it goes below the level as the beams may be lower than the level.
When you say Rotate, do you mean the beam direction or rotate it vertically?
FYI you may get more responses if you post in Revit Structure forum as this is a structural tool
