How can I change the color/material of a family from my model?
svalen
svalen
Do  I need to go into the the family file itself?
For example, I'm trying to change the stock Revit newal post material to wood.
Do I need to add a material parameter?  How can I do this?
Also, a similar topic, how can I assign a family to a new sub-caetgeory that I have created in my model?
Thank you!
Select the geometry in the Family, look under its Properties for "Material" and associate that Parameter to a Parameter in you Family Types Dialog Box. Then reload, select Instance of Family, and assign a Project Material to the Family Material Parameter
You create and assign Subcategories in the Family itself.
You can also change the Category of a Family (for the most part) like this:
