How can I align a wall to a cad that has an angle less than 1 degree?
emilio_bartolini_m
emilio_bartolini_m
Hi!
I can't align a wall to an imported cad because revit finds its a preety small angle
does somebody knows why? the angle tolerance is with 2 decimals
jvpantin2
In fact, you can do it, but Revit will warn about it and keep this warning on "misaligned" element for further fixings. Because you know the 0.2 rule, you may know th rest, anyways I share the Help explanation:
https://help.autodesk.com/view/RVTLT/2023/ENU/?guid=GUID-E8BF9268-4C26-439E-BB27-50EBF3638D3A
As the Revit help says, you have two options: correct the CAD file or repeat the align operation with angle snaps turned on.
The risk here is related to Revit programming math. Sharp angles require more calculation, may cause performance issues and in some cases file damage.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
emilio_bartolini_m
Perfect! it works
