Due to that the wall/curtain walls are not vertical but slanted, the editing becomes difficult. I try to edit it by modifying the profile, however, lots of mullions are lost. The error message is shown below. So what is the best way to edit the slanted curtain wall?
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Try to make it in 3 walls, to avoid having to edit the profile.
I would duplicate the type and set the gridline spacing to none. Then edit the profile and see if that helps.
@syman2000 wrote:I would duplicate the type and set the gridline spacing to none. Then edit the profile and see if that helps.
It does help although it gives same error message but no mullions are deleted.
