how can I add a void to a sink family.
Caed9
Message 1 of 22
Caed9
I already tried creating a family with a "Metric Generic Model face based" template and nesting the sink family and then create the void, but when i load it to the project it has some parameter conflicts.. but why? If I could perfectly load the sink on the project. I attached the family
Accepted solutions (3)
Replies (21)
Message 2 of 22
Where'd you get this crap from?
Message 3 of 22
Caed9
I got it from bimobject hehe
Message 4 of 22
well, I don't know what the hell I'm looking at.  BIMObject you say? Post the link to it, please.
Message 5 of 22
Caed9
Message 6 of 22
Okay, I believe you. I'd download the family but I can't understand the foreign language interface.  But, the rfa you posted doesn't have any Revit characteristics.  It's just plain weird.  Sorry I can't help you.
Message 7 of 22
Caed9
is that is has a lot of symbolic lines for the and masks for the coarse, fine and middle details...
Message 8 of 22
bin
No issue, just create a void to cut the face in the face based family.
Message 9 of 22
I must have been spacing out last night.  There's nothing crappy about this Family at all.  In fact, it's pretty nice.  I think it was originally done in 3D Max.   @bin is spot on.  You can place a Void in the Family to cut the Host in the Project, or you can cut the Host directly, or use one that already has an opening.  Revit has countertop Families with parametric openings.
I placed a couple of Void Cuts in the Family that are sized per the manufacturer's specifications for this particular model. See the attached Family. I added Parameters for the Void Cuts, as  well as a URL Parameter that Links to the PDF I obtained the dimensions from.
Message 10 of 22
ennujozlagam
post your counter top, sink in another file to show you how to cut void. thanks
Message 11 of 22
Is this what you mean, @ennujozlagam ?
BTW @Caed9 , I revised sink family to make top void deeper for recessed installations.  See attached.
Message 12 of 22
ennujozlagam
Yes idol.. I just wonder if the OP doesn't know how to cut and show to him in the screencast. Just saying. Thanks
Message 13 of 22
Good point. I should have mentioned that at the onset.  Thanks.
Message 14 of 22
Caed9
Yeah what I get was that you create void on family editor. but then I do not know how to cut it through once on the project. is it with the simple cut geometry tool?
Message 15 of 22
ennujozlagam
no, you can't cut in your project once loaded, you have to cut from your family itself. thanks
Message 16 of 22
Void in Family will cut countertop in Project using Cut Geometry tool.  Place a checkmark in the box next the "Cuts with Void When Loaded" in the Family.
Message 17 of 22
make a void extrusion and in properties check cut with void when loaded. ur pblm will get solved
Message 18 of 22
If your sink family is a face based family, simply edit it and use the void to cut the host solid.  Then when you load it in project,  place it on the countertop, it will cut the counter automatically.
Message 19 of 22
ennujozlagam
my apology i'm thinking about the counter top and not the sink fixture. thanks
Message 20 of 22
counter top will cut when u place the sink
