Hosted objects misplaced
vanderloo5
vanderloo5
Can anyone explain to me why all of my wall hosted objects are buried into the wall rather than on the surface where they should be?
Note all of the plumbing fixtures in the attachment as well as the  Rinnai Tankless water heater that's half buried in the wall.
It's not clear to me from that view that they are buried in the wall.  Did you check 3D View to verify that they are indeed recessed into the host wall?
You're welcome to post your file here if you want us to inspect it.
vanderloo5
They are definitely submerged in the walls in every view. It would logically have to be something to do with the wall style since multiple different plumbing fixtures are having this issue.
https://www.dropbox.com/scl/fi/2xh4g63mxh50sx7bkyjwg/Miridae_concept_4rvt.rvt?rlkey=99ixbioxj4ia5q44...
Post the RVT - your project file. The RFA means nothing,
vanderloo5
They are not associated.  Select, press Edit Work Plane=>Pick a Plane and then pick the host wall. Bada bing.
vanderloo5
Thank You again sir. I wish I knew why they didn't host to the walls in the first place. I removed and re-inserted them at least a dozen times. Happy New Year!
