Tile bigger than 1ftx1ft
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
yes_and_no
191 Aufrufe, 2 Antworten
How can I make simple tile pattern of 18"x36" (without using jpeg image) ? Whatever I did Rv will return a 12x12 pattern, attached photos.
2 ANTWORTEN 2
Nachricht 2 von 3
imankassab2015
als Antwort auf: yes_and_no
Why you don't use curtain wall as tile material with solid material to create it with any dim you wish
As a workaround
Because with material you will deal with scale of the pic
Accept my answer if it helps you
Nachricht 3 von 3
