Host Material Showing Through Hosted Family
- Mute
- Permalink
- Report
I have run into a problem with hatch graphics sometimes showing through face-based families. I'm using Revit 2019, though this problem has occurred in several versions.
The attached screenshot is an assembly, which is a concrete panel with two faced-based plates. On the left is a portion of the front view and the right is is a portion of the back view. As you can see, the concrete hatch pattern is showing through the plate on the left, but on the right, the plate displays correctly. The two plates are the same face-based family and both views have the same template set to Hidden Line.
This problem seems to come and go at random and sometimes the plate doesn't show up at all - yet it is there when I mouse over it. Is this a graphics card issue or is there a setting that can ensure hosted items are always in the foreground of the host?
