Connect walls of the same type
Marie.j03
Marie.j03
Guys I have been trying to remove the joint line between the walls but it doesnt seem to work. They are same 100% because I am creating them with create similar option but they refuse to join. How can I fix this
RDAOU
@Marie.j03
Place a section or in 3D check if the top level of the upper horizontal wall falls under the cut plane...or vise versa maybe those vertical ones are below cut plane (cut plane level you can check in View Range on the properties palette)
RDAOU
@Marie.j03
I have just noticed also that you have set an underlay...check that those lines are not the lines from the underlay
Marie.j03
Thank you I didn't notice it 《: ●|
