Holes in roof
Holes in roof
steadfasthomeplans
Message 1 of 8
Holes in roof
steadfasthomeplans
I am working on my roof plan, and I can't get rid of these holes. I got this view by setting the view range at 50'.
They aren't there on any other view...
Replies (7)
Message 2 of 8
Are there any shaft in a different phase?  Set the phase filter to None and see,
Also, turn on plan regions and see if you have any there.
Message 3 of 8
RLY_15
If you tab-select those holes, what element shows up in the Properties Palette?
Message 4 of 8
steadfasthomeplans
It doesn't give me the option of changing the phase filter to none,
How do I turn on plan regions?
Message 5 of 8
steadfasthomeplans
I can't select them. When I delete the roof that they run through they disappear... If I move the entire roof they also disappear.
Message 6 of 8
Click on it and you can change.
VG > Anno tab > Plan Region
Message 7 of 8
syman2000
Use The reveal hidden object and see if there are suspected object(s) that is hidden
Message 8 of 8
steadfasthomeplans
That did it, there was something hidden that I couldn't click on. I showed all hidden elements then I was able to click on it and delete it. Thanks!
