Hi All,
Please can someone help me keep my sanity in tact.
I have created a floor (sloped). I now need to create a hole that runs through +/- half of the floor.
But the hole needs to run horizontally through the floor & not vertically.
Anyone have any ideas on how to make this happen?
Thanks.
Solved by Mike.FORM. Go to Solution.
Solved by JL.FCG. Go to Solution.
use a model in place component Void extrusion or sweep and then use the cut tool and select the floor and then the void.
Thank you your help is much appreciated.
I have now got my hole as i wanted it.
I originally tried the model in place thing, but i think i created an extrusion & then tried to cut it. but that didn't work.
