High of walls
High of walls
High of walls
Hi!
I was doing project and in mind time I change high of floor to 350 cm from 340 cm. And still I have mistake with walls on section, but when I checked on properties it should be good whit base and top . But on draw section I can see different like on screen:
The floor is still lower than the level. Regardless, you should attach the walls to the floor above.
