EXCLUDE REVIT FROM. USING NVIDA GEFORCE 820M
Hello.. .i have an i3 HP laptop with nvidia GEFORCE 820m.. .but when using revit 2016..the red shades appear to be blue shades and vice verser
I run the same Revit on a dell desktop with just Intel HD graphics 4400 and it's just perfect
Is there a way I could exclude revit from. Using the Nvidia graphic card?.
When I use the nvidia window.. Revit cannot be excluded.. .
Any help I would be appreciative. ...am really having a problem in determine my project shades
Note: When images are rendered or exported.. They appear as intended.. ..the colour defect (red appearing blue and vice versa) occurs in the view ports
Toggle between Disable/Enable Hardware Acceleration.
Update nVidia videocard driver.
Thank you....it has worked... Hurrayyyy
