Hiding the Line caused by the Split Element Tool.
Is it possible to hide the lines caused by the Split Element Tool?PDHLaw Office.png
Solved it had to click the Linework Tool twice. One for each side of the Split.
constantin.stroescu
If you want to join again the wall splitted elements then you can:
  • use Wall Joins - with Display > Clean Join
  • or a line override if you don't want to join but only to hide lines : Linework > Line Style - <Invisible Lines>
Constantin Stroescu
Awesome. Because at first I was trying to rejoin the walls to get rid of the Split lines and was having a ton of problems with the automatic cleanups. That is a very helpful tip.
