Hide the grey window placement
burowolswijk
burowolswijk
I made an assembly of a wood frame with plasterboard.
And a window placed in it.
The window is hosted on a not visible wall.
The wall is placed at the front of the wood frame.
But when I turn on the Consistent Color in the assembly view a grey rectangle is shown, in the same size as the window.
I also made a section after the window/hidden wall (so the window is not visible anymore).
But the grey rectangle is still being shown.
How can I remove or hide this rectangle?
burowolswijk
I already found it.
You can hide the opening cut in projection.
Select the opening cut - and turn transparent on in elevation
