Hide revision row without deleting clouds?
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
I wonder if it's somehow possible to hide the revisions in the revision row at the sheets without deleting clouds at the sheet and/or views added to the sheets?
We need to accomplish this since we have sort of a collaboration model for printing. with a bunch of different buildings and so on.
Some need to print without the revision rows and some need to have it.
Change the titleblock to one that has no revision schedule.  When done, change it back.
Marcus.Isacsson
I was afraid that this was the best solution. Doesn't "feel" right but I guess it doesn't hurt that much, quite easy to remove and insert again.
magnus.enstrom
One other "solution" is to hide Schedule Graphics and Revision Clouds under V/G Overrides for the sheet and the view, but that wont clear the Current Revision letter down in the bottom of the sheet though.
I guess I would have created a new different sheet and placed the view on the same place and kept it from messing with the revisions from the current project, but I dont know if it has the same name and number as the other sheet and if you run into trouble there instead
/Sweco Umeå
