HIDE ONLY LEVEL LINE
CAN I HIDE THIS LEVEL LINE?
RDAOU
@Anonymous
If it is just for that view, you can simply select the level >> Right click >> Hide in View >> Elements
If you want to hide certain levels on several views...you can create a view filter (which you could also add to the View Template if you wish)
  1. You can either use an existing built-in parameter of the Levels Category (Such as Building Story or Structural)
  2. Or you can use a custom/user created Project Parameter (Manage >> Project Parameters >> Add a new Instance parameter and assign it to the Category Level) - ex: a yes/no "Level Filter"
  3. Create a view Filter and use the yes/no project parameter you created in step 2
  4. Set the condition to equals: yes
  5. Go to the view >> type VV for visibility graphics and under Filters tab Add that filter
  6. Uncheck the box under visibility and Apply
  7. Select the levels you want to filter out/hide and in the properties box check/yes the parameter "Hide levels" which you added in step 2
  8. Uncheck the box under visibility
Level Parameter - Building StoryLevel Parameter - Building Story
Create a VIew Filter to Hide LevelsCreate a VIew Filter to Hide Levels
Visibility Graphics - Add the Hide Level FilterVisibility Graphics - Add the Hide Level Filter
Uncheck the box under visibilityUncheck the box under visibility
1. Crop it out of the View.
2. Hide it in the Views BY ELEMENT
Can you not switch the Levels to 2D extent and grip stretch the line?
