Hide category in 1 view
IanH5033
IanH5033
I have  small model in which some of the generic families contain structural connections. I need to show the families complete with the connections in one view but also need to show the same family without the connections in another view.
RDAOU
@IanH5033
Make the structural connections as a shared nested family (ie: edit the generic model >> edit the structural connection family >> check the shared box >> load back into the generic >> load back into the project
In the view where u do not need the connection >> go to visibility graphics and switch off its category
Associate all the connections to a Visibility Parameter (YES/NO Parameter). Now you can turn them OFF by unchecking the Visibility Parameter checkbox.
And/or, look into Visibility Settings of the connections. That's a way to control connection visibility based on View and View Detail Level .
Several ways:
-  Set the connection components to only visible in Fine detail level and set the views you don't want to see the connections to Coarse or Medium
- Add a subcategory and assign the connections to that category, turn off the subcategory via VG for the views you don't want to see them
*Do not create a Visibility checkbox to turn off the connections.  That will turn them off globally, not per views.
