Hidden line missing in other assembly view
shuaib009
shuaib009
Cant see hidden lines in other assembly view (back elevation)? How can I fix this?
note: I have already checked the view range, its fine.
thanks.
RDAOU
@shuaib009
Copy to clipboard paste in a blank project and upload that to check
shuaib009
Thanks @RDAOU . Attached here for your reference.
RDAOU
@shuaib009
You are trying most probably to pick the Cut Out on the second click...You have to do the following:
  1. View > Show Hidden Lines
  2. Select the Wall (The element to reveal hidden lines through)
  3. Re-select the Wall (The element to reveal in this case is the cut out in the wall itself)
shuaib009
2 more solution will make you 1000 solution landmark 🙂 . thanks.
