Want to change dimension line and dimension text to different colors
Message 1 of 9
I have tried to change the color of dimension line and dimension text to different colors. But it is giving the same color.
I want to change the measured dimension line and dimension text to different colors. Kindly let me know how I can deal with this.
Thanks in advance
Replies (8)
Message 2 of 9
RDAOU
@Anonymous
Select the dimension >>> Edit type >> Duplicate >> Add the color name as a suffix to the new style and set the color
When placing the dimension, make sure you are selecting the right Dimension type from the drop down menu
Create a new Dim TypeCreate a new Dim Type
Make sure you select the newly created type when placing a dimensionMake sure you select the newly created type when placing a dimension
Message 3 of 9
Thank you @RDAOU for your information. I have tried with what you have shown here in the images.
With due respect I just want to clear you my issue that I want to change dimension line color to cyan color and dimension text color to red. So kindly let me know how to do that.
Message 4 of 9
RDAOU
@Anonymous
Not possible  ... max you can achieve is something similar to the below (2 Dimension Types overlayed on top of each other
Message 5 of 9
Yes thank you @RDAOU but it is the correct way to do that right ?
Anyway thanks for your information. In rare cases we can use this trick.
Message 6 of 9
RDAOU
@Anonymous
I do not know any other way to have a 2 color Dimension Type...
There is a possibility to create a line based detail item with a label that reads length ... ie: it would imitate tha Dimension but it is not actually one...this you can mix and add colors to it as you wish
Message 7 of 9
@RDAOU Could you tell me how to do that ? I can give a try to this.
Message 8 of 9
RDAOU
@Anonymous
Sure, here is a sample family you can look into and customize. (Note: After placing it you need to align and lock its ends to the element you are dimensioning to in order for it to stretch along and update - Remember this is a line based detail item with a generic annotation)
Message 9 of 9
@RDAOU Yes I will definitely try this. Thanks for sharing
