HELP with uneven ceiling tiles
Message 1 of 8
Hi I have attached a small layout of a ceiling that I am trying to configure using Revit 2020.2  I've been able to draw a reflected ceiling plan in the model, however, I haven't a clue as to how to create a ceiling grid that is uneven.
I've not been using revit for long so the simpler the instruction the better! 🙂
Replies (7)
Message 2 of 8
martijn_pater
Use a model pattern, you could easily make one with PyRevit plugin or some other plugin.
Message 3 of 8
If I have to d/load this plugin, I won;t be able to do this as I am using the office PC.
Message 4 of 8
Are the ACT panels actually 540x1470 and 320x1470?
Message 5 of 8
That's what they measured on site! So this is the size to use.
Message 6 of 8
Model Pattern would be the easiest, but you could model the ceiling using Slope Glazing (Mullions for Framing and Curtain Wall Panels for ACT Panels).  Might be a little much if this is an as-built though.
...of course, your lights would need to be Face-Based, not Ceiling-Based if you went this route..
...do a shout out to the forum for a model hatch pattern. You don't need any software. Just need a *.pat file.
Message 7 of 8
See attached 2019 file.
Message 8 of 8
Thanks, this works great! #lifesaver
