Attach columns with sloped slab
mairh_tsek
mairh_tsek
Hello all,
I need to model a complex slab in Revit with many slopes..I will try to modify thesub-elements.
I did an example and I cannot find how I could attach the columns with this slab. If I move the columns from the section it will not very precise..
Thank you
twebb4CYQY
When you select the column you will have the option, in the options bar, to attach the column, you can choose top or bottom of column. Then select the slab to attach it to. Typically I’d do this in section to ensure it works as I desire. If the slab and column are of identical material type it will also clean up very nicely.
mairh_tsek
ok, basic thing that I didnt know.. Thank you!!
