Hello.
I have a problem with revit tags. When I try to put a tag on a column the text is not centered to the line and I can't find a way fix it. Here's an image to explain better my problem:
As you can see the C-1 text is shown above the line instead of showing right next to it. Plese help.
Solved by Lechuza_Amatar. Go to Solution.
It looks Like there may be come "Retuns" in the Tag with blank lines below.
Or additional labels but I doubt this as ? would be visible if no information was reported.
you will have to Select the Tag > Edit Family and investigate
I fixed it, just in case this happens to anyone, the problem was that the tag was off center in the edit family.
I didn't notice because this was the default tag in the template. I realized this when I decided to create a new one.
