I am drawing tile layouts in revit for a project. I have created a new floor and am dividing the new floor into parts to show tile layout. When I go into 3d view the tile layout is still visible but when I go into the assigned floor plan it disappears. I have tried playing about with view templates etc but still no further on. Please help. OD
... can you upload a picture describing the issue
.... or the .rvt file
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Hi i hope the screenshots show what the issue is. Thanks for your help.
@Anonymous wrote:I have created a new floor and am dividing the new floor into parts to show tile layout.
Parts? Is the view set to show Parts or Both -- or is it set to Original?
... is it when you are inserting the views into sheets?
... if so could be a visibility issue
... check if your title is set to visible
aRcHiTeCt.JM
REVIT EXPERT ELITE
When I change the part visibility to 'Show Parts' the floor disappears.
When I have the part visibility set to 'Show Original' or 'Show Both' The parts do not appear
it is currently set to show original, when I change it to show parts the floor deletes
