Help With Complex Mass Shape
Hello!
I am having quite the struggle in terms of making a very complex mass shape.
I am trying to design this:
It's a very unusual shape, however I can't seem to figure out a way to make this! If anyone could help me out with this that would be amazing!
This is the closest I could get...
constantin.stroescu
is it something like this?
if it is , have a look at this screencast (a void form needs to be added):
https://knowledge.autodesk.com/community/screencast/5b4636d0-d832-4f21-98bf-b409a311e7dd
Constantin Stroescu
Wow!
This is perfect! Thank you so much!
I have followed your screen cast and it worked perfectly!
However, o you know of any way to lower the top tip to spiral down into itself?
Thanks!
constantin.stroescu
if you mean the void that penetrates from above ,  some thing like this:Image 1.png
then have a look at the following screencast:
https://knowledge.autodesk.com/community/screencast/81db2a50-1c93-4630-921a-979a28175df9
Constantin Stroescu
constantin.stroescu
Of course that you can use Wall by Face but the shell will be even and too rigid. So I'll propose to make a hole by using Void as follows:
  • when you appreciate the exterior Form fits your purpose, select the Element and Copy it to clipboard.
  • then Paste it into the Same Place , creating so an other instance of the Form Element .
  • select the new created instance an scale the Profiles as you need to
  • turn the second Form into a Void to cut the first Form
https://knowledge.autodesk.com/community/screencast/3d4a824d-6e43-4e33-a01e-df355f4b49d7
Constantin Stroescu
