Help with Area Schedule
gzavalagaMP7PK
Message 1 of 11
gzavalagaMP7PK
Hello, I need help creating an area breakdown schedule for a project I'm working on. The image below is what I'm trying to accomplish, right now this schedule only has the SF in just text that I would have to manually add. Is there a way to have areas be divided into different categories automatically (retail, resident, amenity, etc?).
Replies (10)
Message 2 of 11
Alfredo_Medina
Yes, if you enter something in a parameter of each Area item, such as in "Department". Then you can sort your schedule by levels then by department. The appearance will be different than in your sample image.
Message 3 of 11
Yes. You would add a set of yes no parameter for the type of use, and a set of calculated value parameters to show the value when the yn conditions are met.
Message 4 of 11
gzavalagaMP7PK
Thank you. I created the yes/no parameters for each use, how can I create the calculated value parameter?
Message 5 of 11
Add Calculated Value Parameter:
- name = AMENITY AREA
- type = Area
- formula: if (AMENITY, Area, 0)
Repeat for all others.
Message 6 of 11
gzavalagaMP7PK
Thank you! I still seem to be having problems with the formula, I'm getting error messages when I put the commas, and when I delete them:
Message 7 of 11
gzavalagaMP7PK
Message 8 of 11
ralphdenhaan
Use exactly this formula:
if(AMENITY, Area, 0)
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 9 of 11
gzavalagaMP7PK
Thank you! This added the column to my schedule but there's nothing under it 😕
Message 10 of 11
syman2000
You have to go to formatting and set the calculated value as count total.
Message 11 of 11
ralphdenhaan
You also have to check the boxes in the schedule in order to get a value. They are probably greyed out for now.
