Message 1 of 21
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I want a L-shape stair with the size roughly like as below to fit the floor from level 1 to level 2, so I draged the stair to make the size to fit.
But it turns out like this, the support carriages are not even at two sides, and offset from the base floor.
The warning says that I should change the stair run's Relative Top and Base Height parameters, but if I changed them to 0, the length on the short side of L shape would be too long to fit the space.
What can I do with this, please help!
