Help! What's wrong with my stairs?
tanniana
Message 1 of 21
tanniana
Hi, I want a L-shape stair with the size roughly like as below to fit the floor from level 1 to level 2, so I draged the stair to make the size to fit.
But it turns out like this, the support carriages are not even at two sides, and offset from the base floor.
The warning says that I should change the stair run's Relative Top and Base Height parameters, but if I changed them to 0, the length on the short side of L shape would be too long to fit the space.
What can I do with this, please help!
Replies (20)
Message 2 of 21
Post the RVT here. Know how?  Attach it to a reply post.
Message 3 of 21
@tanniana wrote:
Hi, I want a L-shape stair with the size roughly like as below to fit the floor from level 1 to level 2, so I dragged the stair to make the size to fit.
Red flag right there.  Undo it and use Move instead of dragging the grips.
Message 4 of 21
tanniana
Hi, I attached it now, thanks
Message 5 of 21
Nothing attached. Wait for it to fully load before pressing "Post".
Message 6 of 21
tanniana
what do you mean, I will try it, but I guess I moved it, not so sure.
Message 7 of 21
tanniana
ok
Message 8 of 21
I mean you should not drag the grips of the stair run when editing the stair.
Message 9 of 21
tanniana
I am not able to do it, I saw it uploaded, then click  the Post, but it disppeared.
Message 10 of 21
It's lagging today.  Give it a few moments to fully upload.
Message 11 of 21
tanniana
I started a new project to try it, the problem remains the same.
Message 12 of 21
How's it look in 3D? I'm thinking it looks weird because of where the cut plane is for that Section View.
Message 13 of 21
tanniana
It looks like this.
Message 14 of 21
Can you point out in the picture below which dot did you drag?
Message 15 of 21
@tanniana wrote:
It looks like this.
I'm not seeing a problem with the stringers.   What am I missing?
Message 16 of 21
tanniana
Hi, I moved the red dot, because that's the only way to get the shape I want, the blue arrow cannot get the desired size.
Message 17 of 21
tanniana
On the first pictures I post, you can see the support carriage on the left side is lower than the right, and they lifted above the base floor I want it to land.
Message 18 of 21
Yeah.  That is the reason I marked them red.  Don't move them because that would change the run's base and top offset, meaning your run is not at the original elevation.  You can change size and move using any other grips to get what you want.
Green arrows: adjust start and end of run.
Pick arrows: adjust width
Orange dots: adjust location.
Red dots: adjust base on top offset (don't touch them).
Message 19 of 21
tanniana
Ok, I get it. But can you try the stair with the size I need, with the type Private, and I can see what parameters I may set wrong. Thanks a lot
Message 20 of 21
Try this.  You can adjust a few risers to meet the exact dimension but it should work.
