Help to create Hatch Pattern (Pat File)
Message 1 of 8
Dear all, I tried so many times for that hatch pattern but still not yet correct. Pls help to create hatch pattern below image
Replies (7)
Message 2 of 8
ennujozlagam
you can refer to this LINK and see if helps. thanks
Message 3 of 8
Let's check out your txt file.  Post it.
Message 4 of 8
Pattycake_Kyle
Hey @Anonymous
Here ya go: https://pattycake.io/pat/YlRY9e4wveQ
This one was written by hand, you can learn more how to do that through this tutorial we put together.
However, you can also use this one: https://pattycake.io/pat/Yll1WNdrWGG
This was made (much) easier by just drawing it in our draw in web - you don't need to 'understand' the PAT syntax at all.
Both will function the exact same in revit. We've tested this thoroughly --- there is no performance difference/degradation in PAT files of this size (generally you are safe up into hundreds of lines before any issue shows up - and it has more to do with density of the PAT and tolerance/precision than # of lines).
🎂Cheers!
Night mode is dope modeNight mode is dope mode
Draw in Web rocks our socksDraw in Web rocks our socks
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Message 5 of 8
hugha
The equivalent and equally efficient pattern is directly available on filling in block size and offset as shown in the attachment:
; Written by HatchKit 4 Standard Edition
; HatchKit 4 Standard Edition (c)1990-2021 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2021/05/28
;-Time : 18:13:53
;-HatchKit 4 Version : 4.1.4.3038
;-HatchKit 4 Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*Phyoei,
;%TYPE=MODEL
0,0,0,0,300
90,0,0,-2100,50,300,-3300
hth,
Hugh Adamson
www.hatchkit.com.au
Message 6 of 8
marlette
I am trying to create a custom hatch for a staggered, woodplank, random looking hatch.
I need it in 1220 x 230mm.
I tried to adjust this 100 x 800 pattern. But just don't get it to work. I even asked chatgpt, but it couldn't figure it out either. Can someone please assist?
;%UNITS=MM
*100 x 800mm Wood Board, Wood: Wide boards
;%TYPE=MODEL
0, 0, 20, 0, 100
90, 0, 20, 200, 200, 100, -700
90, 400, 120, 200, 200, 100, -700
How can I get this wood board look in 1220 x 230mm?
Message 7 of 8
hugha
try:
; HatchKit 4 Standard Edition (c)1990-2023 Cadro Pty Ltd
;-Date : 2023/05/19
;-Time : 14:45:39
;-HatchKit 4 Version : 4.3.1.3212
;-HatchKit 4 Output Filetype : Revit® with HatchKit Fill Manager
;%VERSION=3.0
;%UNITS=MM
*230x1220mm Wood Board,Wood: Wide boards
;%TYPE=MODEL
0,0,0,0,230
90,610,230,-1380,305,230,-1610
90,0,0,-1380,305,230,-1610
hth,
Hugh Adamson
www.hatchkit.com.au
Message 8 of 8
marlette
it works! thank you!
