- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have a deadline in our office this week and every single day we've had the following two messages appear: "Revit cannot reconcile the differences between your local file and the central model. You can find more information about the errors in the Worksets dialog" - this happens when we try to reopen our local; "Revit cannot synchronize this file with the central model, because the central model was rolled back to a prior version of the project" - this happens when we try to sync our local.
Today it happened 3 times! We lose hours of work as well as additional time searching for the most up to date local/central model to recreate a central from. We've had this happen previously in the past but much less frequently so we mostly lived with it. We are using 2017 now though and we noticed it creates a conflict copy every time this happens in the central file directory. I've found nothing definitive looking at worksets and searching on the internet.
Our new team member mentions they had a similar problem in his old office where this happened and it turned out to be something with the server. The path would not be a direct drive path and revit wouldn't be able to find the central so this error occurs. He mentioned that making the path a universal naming convention fixed the problem or something like that - I'm not a techguy so I'm not sure if any of that even made sense.
Could this be our problem? Or is it something else. Please help we are losing countless hours of work do to this mess.
