Help! My Floor Plans disappeared - How to retrieve them??
Message 1 of 11
I imported a scanned drawing into Revit and traced it.  I put the walls and floors in, then was inserting doors.  I tried to find a particular door, but found I clicked on the wrong door and closed Revit instead of the screen I was in.  However, when I brought Revit back up, I could no longer see any Floorplan, but my 3d was still visible.  How do I retrieve or make visible Level 1 or 2?  (When I tile the Floorplan Level 1 and the 3D drawing, my 3d drawing will turn blue if I box in the blank area on my Floorplan screen, so I assume it must still be there).
The other question I need answered is how to insert the geometric figure/camera that shows each side of an elevation?  When I imported my scanned drawing, it was much larger than the area within the four “eyeballs”, but I have tried moving it and don’t see them.
PS - I am new to Revit.
Thanks for any help as soon as possible!
Replies (10)
Message 2 of 11
Stephm419
Go to the views tab. Then pick Plans Views then pick Floor Plan
Message 3 of 11
And what if the Plan is not available to be regerated, meaninng, it is not showing on the View tab to be generated?
Message 4 of 11
Okay, I had the same problem. Go into the "View" tab and click "Plan Views" as you tried before. Below the box where you see no options, there should be a check box that says "Do Not Duplicate Views," in which this box will be checked. Uncheck the box, and your views should be in the box. Click on a view, and it will take you to that floor plan view. Hope this helps!
Message 5 of 11
"closed Revit instead of the screen I was in"
It's easy to hit that X to close Revit, but there
will always be a dialog saying "Do you want to
save changes to project xxx". Just hit "cancel"
and Revit won't close.
Message 6 of 11
I was able to retrieve my floor plans but I am still missing the entire levels, views, elevations, families etc tab that is normally in the left hand side when you open revit. How can I retrieve this? Is it a setting problem? I would like to be able to view my elevations. Please help.
Message 7 of 11
Go to the view tab, and on the far left there will be a user interface icon, click on that and then click project browser it will bring up the plans.
Message 8 of 11
Thanks you Brother ... reaaaaaalllyyyy
Message 9 of 11
grapevine2906
Community Visitor
Community Visitor
I'm a Revit Newbie and this happened to me too.  At least... I got to a point where the Floor Plan view was available... but whenever I clicked on it there was nothing there.   All the other views, North/South/East/West/Ceiling/3D/etc, etc... all worked but whatever I did the floorplan view was blank.   I finally thought to myself... what if I accidentally somehow zoomed in way too much or I zoomed out way too much... so I did a "zoom-to-fit" command and ta-da!!   Everything was there.   Just right-click in the view and Zoom-To-Fit is one of the options when you right-click in any view.   Just a thought.   That was my issue... stupid as it was.
Message 10 of 11
melissavgZTGBN
Community Visitor
Community Visitor
life saverrrr
Message 11 of 11
melissaflynn_art
Community Visitor
Community Visitor
Duuuuuude thank you!!!!! Been going nuts trying to figure this out!
