- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I imported a scanned drawing into Revit and traced it. I put the walls and floors in, then was inserting doors. I tried to find a particular door, but found I clicked on the wrong door and closed Revit instead of the screen I was in. However, when I brought Revit back up, I could no longer see any Floorplan, but my 3d was still visible. How do I retrieve or make visible Level 1 or 2? (When I tile the Floorplan Level 1 and the 3D drawing, my 3d drawing will turn blue if I box in the blank area on my Floorplan screen, so I assume it must still be there).
The other question I need answered is how to insert the geometric figure/camera that shows each side of an elevation? When I imported my scanned drawing, it was much larger than the area within the four “eyeballs”, but I have tried moving it and don’t see them.
PS - I am new to Revit.
Thanks for any help as soon as possible!
