Help me with this, Materials are locked unable to load them to project, after applying wall...
FacebookGroupMember
FacebookGroupMember
Help me with this, Materials are locked unable to load them to project, after applying wall material is not changing
FacebookGroupMember
Step 1. Look into twin motion.
I love revit but not for rendering or visualisation.
FacebookGroupMember
Material is in library not the project. Drag and drop to project. If image is missing then add a path to revit where it looks for images used when rendering. Options.
RDAOU
It is not locked, Revit is unable to find the path to the folder where the image is located. (ie: the images were either relocated or deleted)
Under appearance tab >>> click the link to the image >>> navigate to the folder where it is located >> select the image and click OK
FacebookGroupMember
Thank you most helpful
FacebookGroupMember
If you do not have current material libraries loaded, you can use material libraries from previous releases.
Also, make sure you have “use render appearance” checked in material identity.
