Door Tags and Window Tags have all the same tag number by type
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
2877 Aufrufe, 4 Antworten
Hello.
This has been bothering me for far too long. I think it's an issue with Revit 2022. Whenever I use Tag All and then select Window/Door Tags, the tag numbers for different types of windows/doors have all the same value. For example, the window tags for fixed windows is all number 1 while the window tags for sidelight windows is 28. I don't even know how it got to 28.
See image below.
I hope you fellows can help me.
Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: Anonymous
@Anonymous
  1. If you are using the OOTB window tag, the label in it is Type Mark. IE:
    • Either all your windows are the same Type
    • OR all your window types have the same Type Mark
  2. If you are using default OOTB window families, these have preset type mark. That is where the 28 came from
    • Edit Family and check Type Mark values)
You can attach the revit model/file for a closer look
Nachricht 3 von 5
als Antwort auf: RDAOU
Thank you.
I was able to change the Type Mark with Mark by editing the window tag family. The tag numbers are now sequential but the number now starts with 6 instead of 1.  How do I make it start with 1 without having to change all tag numbers?
Nachricht 4 von 5
You can search for a dynamo script for renumbering elements marks. It is a
quite popular on dynamo forum. Some adding such as pyrevit may be able do
that too but I don't have Revit now so I can't confirm.
Nachricht 5 von 5
@Anonymous wrote:
Thank you.
Might be easiest to create a Window Schedule that includes Mark Parameter and then change the Mark value through the Schedule.  Also, there is a free Add-In named PyRevit  that has a Renumbering tool, along with a bunch of other useful  tools.
