HELP ME CREATE THIS DOOR
pvshafna88
pvshafna88
Community Visitor
Community Visitor
Hi there,
I was figuring out to create this door attached here door so long,i know how to create the frame and door panel but not those vertical  grooves. This is a 2 paneled door. Please find the model attached.
Simon_Weel
Do you really need those grooves? I think I would apply a material using an image of grooved wood. But anyway, if you'd like to create those grooves, I would create an extrusion in plan view and draw all those grooves as a zig-zag line. Or create a similar extrusion as void and use that to cut out the grooves in the doors and frame.
azad.Nanva
Do you need something like this?
if it is really emergency , in other wise use the material.
