Help: I can't create elevations inside a callout. The button appears disabled.
robsonrogers
robsonrogers
Hi, I'm trying to create an elevation inside a callout but I can't cause the elevation button appears disabled when I am inside a callout view. Can you guys help me? Problably it's a template constrain.
Creat the call-out as a floor plan view instead of a detail view then you should be able to place elevations.
Pshupe
Solution is above.  If you want, create a new Floor Plan view type for your Plan Details.  That way you can add Elevations and also organize in a separate view type folder for "Plan Details".
Cheers Peter.
robsonrogers
How do I create a callout as a floor plan view?
When you start the call-out tool, choose Floor Plan from Type properties.
Pshupe
When you initially select the callout, check the type selector and switch it to Floor Plan instead of Detail View.
Cheers Peter.
