I have been using Revit and its coordinate systems for well over 8 years and I would say i'm an advanced user, usually having no trouble with getting things set up the right way. BUT, sometimes I still get all confused using DWGS and shared coordinates. When I belive everyting is set and I close and reopen a revit file, all my linked DWGs have rotated and I cant replace them in the proper positions. Makes me go crazy (I have searched the forums but my tired head still does not connect the dots at this moment..).
This is my current workflow for a project, what am I missing?
1. I start with drawing a building. PBP is at Internal Origin, SP is 0,0 no rotation also at Internal origin.
Then I link a site dwg with the building outlines and a known position of world coordinates (green arrow). I rotate it in place and aquire coordinates from the dwg, to get the rotation (because of line jagging in imported world coordinate dwg site file, i have moved the objects closer to the origin in this file and kept a reference point). Then I specify the actual world coordinates at the known point. Now i have a true north with proper rotation and if I export DWG from shared coordinates they align nicely with other DWGs using world coordinates.
Now i want to IMPORT some nice site plan drawing or similar drawn in autocad using world coordinates. I want the 0,0 in the autocad file align with the 0,0 of the Survey point. I also want to do this in a true north view inside of Revit to just have the building sit nicely atop of the site dwg.
This is where im starting to get lost. I import it using "current view only" and it a little pop up tells me exactly what i want. Then I look at the result and Im lost. The dwg seems to be aligned with project north and not true north!
I set my view to project north and redo it. Niice - it works. I reset my view to true north. Now it looks like I want.
Then I close my file. And Revit asks me something. I dont know what to say.
I try the first one. Then I reopen my file. I go to my site plan view. And i cry. The dwg has moved! and my first dwg as well. AndI cant redo the workflow without renaming my dwgs because the "already share coordinates". I make new dwgs and I try all options but the result is always the same! The dwg are not in position when i reopen the file. .
How can I just keep things in place?
