Help: I can't create elevations inside a callout. The button appears disabled.
5 ANTWORTEN 5
Nachricht 1 von 6
robsonrogers
363 Aufrufe, 5 Antworten
Hi, I'm trying to create an elevation inside a callout but I can't cause the elevation button appears disabled when I am inside a callout view. Can you guys help me? Problably it's a template constrain.
Beschriftungen (3)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: robsonrogers
Creat the call-out as a floor plan view instead of a detail view then you should be able to place elevations.
Nachricht 3 von 6
Pshupe
Solution is above.  If you want, create a new Floor Plan view type for your Plan Details.  That way you can add Elevations and also organize in a separate view type folder for "Plan Details".
Cheers Peter.
Nachricht 4 von 6
robsonrogers
als Antwort auf: ToanDN
How do I create a callout as a floor plan view?
Nachricht 5 von 6
When you start the call-out tool, choose Floor Plan from Type properties.
Nachricht 6 von 6
Pshupe
When you initially select the callout, check the type selector and switch it to Floor Plan instead of Detail View.
Cheers Peter.
