Can someone help me with this? Please see attached cap-image. The generic annotation is aligned with the walls, I want to make it away from wall. What should I do?
Solved by barthbradley. Go to Solution.
Hii Zapatero alfons
-->Just give the leader for generic annotation tag and move the tag to the required place, and now switch off the leader. Now the annotation tag will not be overlapped.
-->Or else just you can click and drag the tag if the leader is not required.(TAB key is used to select the particular annotation tag)
Aadityan Gokulakrishnan
Dear Alfonso,
-->Then you can edit the family and make the changes.
-->If it doesn't work, can u just upload the family here. I will try to make the change.
Aadityan Gokulakrishnan.
What not just use a Tag in the Project and not have a label in the Family? Do you understand how to do that (e.g. create a Tag to pull information from a Family)?
