' 0:< Initial VM: Avail 134213242 MB, Used 16 MB, Peak 16; RAM: Avail 4895 MB, Used 56 MB, Peak 16
' 0:< GUI Resource Usage GDI: Avail 9999, Used 1, User: Used 3
'C 15-Mar-2019 12:44:36.540; 0:< started recording journal file
' Build: 20170223_1515(x64)
' Branch: RELEASE_2018_SHIP
Dim Jrn
Set Jrn = CrsJournalScript
'C 15-Mar-2019 12:44:36.540; 0:< ->desktop InitApplication
'C 15-Mar-2019 12:44:36.561; 0:< <-desktop InitApplication
'C 15-Mar-2019 12:44:36.561; 0:< ->desktop InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2018\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2018\Libraries\US Imperial\Detail Items (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -21 -> 134213222 MB, Used +4 -> 21 MB, Peak +4 -> 21 MB; RAM: Avail -71 -> 4824 MB, Used +11 -> 68 MB, Peak +11 -> 68 MB
' 0:< GUI Resource Usage GDI: Avail 9983, Used 17, User: Used 30
'C 15-Mar-2019 12:44:40.220; 0:< License initialization complete
' 0:< License version: 18.5.4.1
' 0:< ::0:: Delta VM: Avail -180 -> 134213042 MB, Used +31 -> 52 MB, Peak +33 -> 55 MB; RAM: Avail -279 -> 4545 MB, Used +49 -> 117 MB, Peak +49 -> 117 MB
' 0:< GUI Resource Usage GDI: Avail 9983, Used 17, User: Used 54
' 0:< SystemSettings:
' 0:< 4=multiCoreCharacteristic
' 0:< true=isDotNetInstalled
' 0:< 4.7.03056(461808)=dotNetInstalledVersionString
' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -21 -> 134213022 MB, Used +8 -> 60 MB, Peak +5 -> 60 MB; RAM: Avail -147 -> 4399 MB, Used +16 -> 133 MB, Peak +16 -> 133 MB
' 0:< GUI Resource Usage GDI: Avail 9977, Used 23, User: Used 68
'C 15-Mar-2019 12:45:05.077; 0:< manage licensing
' 0:< ::0:: Delta VM: Avail -47 -> 134212975 MB, Used +4 -> 64 MB, Peak +4 -> 64 MB; RAM: Avail +148 -> 4548 MB, Used +12 -> 145 MB, Peak +12 -> 145 MB
' 0:< GUI Resource Usage GDI: Avail 9977, Used 23, User: Used 70
' 0:< License mode: Standalone
' 0:< Status: Your license will expire in 943 days.
' 0:< Type: Standalone - Locked
' 0:< Usage: Student Version
' 0:< Behavior: Extendable
' 0:< Expiration: Wednesday, October 13, 2021
'C 15-Mar-2019 12:45:11.500; 0:< manage involvement
' 0:< ::0:: Delta VM: Avail -581 -> 134212395 MB, Used +40 -> 105 MB, Peak +45 -> 110 MB; RAM: Avail -141 -> 4407 MB, Used +48 -> 193 MB, Peak +48 -> 193 MB
' 0:< GUI Resource Usage GDI: Avail 9945, Used 55, User: Used 121
' 0:< Setting WPF rendering mode to SoftwareOnly
' 0:< ::0:: Delta VM: Avail -129 -> 134212266 MB, Used +68 -> 174 MB, Peak +64 -> 174 MB; RAM: Avail -77 -> 4331 MB, Used +87 -> 281 MB, Peak +87 -> 281 MB
' 0:< GUI Resource Usage GDI: Avail 9827, Used 173, User: Used 201
' 0:< Autodesk Revit 2018
' 0:< 64-bit load point = C:\Program Files\Autodesk\Revit 2018
' 0:< this journal = C:\Users\Michael\AppData\Local\Autodesk\Revit\Autodesk Revit 2018\Journals\journal.0033.txt
' 0:< Journal Init
'C 15-Mar-2019 12:45:23.907; 0:< Log Summary
' 0:< .Count
' 0:< ...PendingMessages = 38
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 51
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 4
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
' 0:< BC: 0,0,0
'H 15-Mar-2019 12:45:23.908; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Construction Template=$AllUsersAppData\Templates\US Imperial\Construction-Default.rte, Architectural Template=$AllUsersAppData\Templates\US Imperial\default.rte, Structural Template=$AllUsersAppData\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=$AllUsersAppData\Templates\US Imperial\Mechanical-Default.rte"
Jrn.Data "JournalDefaultViewDiscipline" _
, "Coordination"
Jrn.Directive "Version" _
, "2018.000", "2.154"
'H 15-Mar-2019 12:45:23.914; 0:<
Jrn.Directive "Username" _
, "mbernalE73UW"
'H 15-Mar-2019 12:45:23.926; 0:<
Jrn.Directive "CategoryDisciplineFilter" _
, -1
Jrn.Directive "DisciplineOption" _
, 7677
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
'H 15-Mar-2019 12:45:23.927; 0:<
Jrn.Directive "AllowLinkSelection" _
, 1
Jrn.Directive "AllowFaceSelection" _
, 0
Jrn.Directive "AllowUnderlaySelection" _
, 0
Jrn.Directive "AllowPinnedSelection" _
, 1
Jrn.Directive "ThinLinesEnabled" _
, 1
'C 15-Mar-2019 12:45:24.019; 1:< logging master created MasterQueue Session20304_P0MasterQueue
'C 15-Mar-2019 12:45:24.019; 1:< logging started queue minder
'C 15-Mar-2019 12:45:24.019; 1:< logging started worker services
' 0.274699 1:<<<Initializing Slave Process
' 0:< ::0:: Delta VM: Avail -60 -> 134212207 MB, Used +1 -> 175 MB, Peak +1 -> 175 MB; RAM: Avail -90 -> 4242 MB, Used +6 -> 287 MB, Peak +35 -> 316 MB
' 0:< GUI Resource Usage GDI: Avail 9826, Used 174, User: Used 201
' 0:< API_SUCCESS { Registered an external service: Name(DirectContext3D Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(SteelConnectionsService); VendorId(ADSK); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Site Insert Service); VendorId(ADSK); ServiceId(c9979a42-11ab-4c25-93e1-abfb50b7be60) }
' 0:< API_SUCCESS { Registered an external service: Name(RebarUpdateService); VendorId(ADSK); ServiceId(a2c22b44-c231-4d3f-b653-b81b6f8be150) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource UI Service); VendorId(ADSK); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Registered an external service: Name(Point Cloud Snapping Service); VendorId(ADSK); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe fitting and accessory pressure drop UI service); VendorId(ADSK); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< ::0:: Delta VM: Avail -4 -> 134212203 MB, Used +5 -> 181 MB, Peak +5 -> 181 MB; RAM: Avail -83 -> 4159 MB, Used +14 -> 302 MB
' 0:< GUI Resource Usage GDI: Avail 9826, Used 174, User: Used 203
' 3.147629 1:<<<DictionaryAnalysis::initialize
' 0:< ::0:: Delta VM: Avail -245 -> 134211958 MB, Used +67 -> 248 MB, Peak +67 -> 248 MB; RAM: Avail -103 -> 4056 MB, Used +91 -> 394 MB, Peak +77 -> 394 MB
' 0:< GUI Resource Usage GDI: Avail 9826, Used 174, User: Used 202
' 0:< To make IFC server work.
' 0:< API_SUCCESS { Registered an external server: Name(Autodesk Drive); VendorId(ADSK); ServerId(baddc547-d952-4d29-ae01-16e71e75aa63); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: ConnectedDesktopDB, Class: ConnectedDesktopDB.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\ConnectedDesktop\ConnectedDesktopDB.dll }
' 0:< Third Party Updater 'CoordinationModelDB: CoordinationModelDBUpdater' registered for all documents.
' 0:< ::0:: Delta VM: Avail -2 -> 134211957 MB, Used +0 -> 249 MB, Peak +2 -> 251 MB; RAM: Avail -35 -> 4021 MB, Used +4 -> 399 MB, Peak +5 -> 399 MB
' 0:< API_SUCCESS { Registering DocumentOpened event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< ::0:: Delta VM: Avail 134211957 MB, Used 249 MB; RAM: Avail +13 -> 4035 MB, Used 399 MB
' 0:< API_SUCCESS { Registering DocumentChanged event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Starting External DB Application: CoordinationModelDB, Class: Autodesk.CoordinationModelDB.CoordinationModelDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\CoordinationModel\CoordinationModelDB.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default DB Server); VendorId(ADSK); ServerId(bd4f0f53-394a-4468-b37e-1e7949013382); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Starting External DB Application: KeynoteDBServer, Class: KeynoteDBServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\Keynote\KeynoteDBServer.dll }
' 0:< ::0:: Delta VM: Avail -1 -> 134211956 MB, Used 249 MB; RAM: Avail -12 -> 4024 MB, Used 399 MB, Peak +0 -> 400 MB
' 0:< API_SUCCESS { Registered an external server: Name(Plumbing Fixture Flow); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshul-Tsal Equation); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< ::0:: Delta VM: Avail 134211956 MB, Used 249 MB; RAM: Avail +12 -> 4036 MB, Used 399 MB
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Starting External DB Application: StraightSegmentCalculationServersApp, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\StraightSegmentCalculationServers.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Coefficient from ASHRAE Table); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(K Coefficient from Table); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: FittingAndAccessoryCalculationServers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\FittingAndAccessoryCalculationServers.dll }
' 0:< ::0:: Delta VM: Avail -4 -> 134211953 MB, Used +0 -> 250 MB; RAM: Avail -13 -> 4024 MB, Used +1 -> 401 MB, Peak +1 -> 402 MB
' 0:< API_SUCCESS { Registered an external server: Name(SteelConnectionsServer); VendorId(ADSK); ServerId(9c209d4a-ec98-460f-bfde-38f17a3443b4); ServiceId(282385f9-9627-4057-8b74-826d019f103c) }
' 0:< API_SUCCESS { Registered an external server: Name(FramingProfileServer); VendorId(ADSK); ServerId(54e490cd-8809-4dbb-84dd-dc0bc6cb1712); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Starting External DB Application: ExternalResourceDBServer, Class: RvtSteelConnectionsDB.SteelConnectionDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\SteelConnections\RvtSteelConnectionsDB.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Site Linker Utility Application (01673995-d4d5-4c62-a184-98e970ef7805). }
' 0:< API_SUCCESS { Registering PositionsSaved event by application Site Linker Utility Application (01673995-d4d5-4c62-a184-98e970ef7805). }
' 0:< API_SUCCESS { Starting External DB Application: Site Linker Utility Application, Class: SiteLinker.SiteServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit 2018\AddIns\SiteLinker\SiteLinker.dll }
' 0:< ::0:: Delta VM: Avail -3 -> 134211951 MB, Used +1 -> 251 MB; RAM: Avail -20 -> 4004 MB, Used +3 -> 405 MB, Peak +3 -> 405 MB
'C 15-Mar-2019 12:45:50.209; 0:< Journal Logger Registered with Application Services, from within CollaborateDB Addon
' 0:< API_SUCCESS { Registering DocumentOpening event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Starting External DB Application: CollaborateDB, Class: Autodesk.Revit.UI.Collaborate.CollaborateDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateDB.dll }
' 0:< ::0:: Delta VM: Avail -26 -> 134211925 MB, Used +9 -> 260 MB, Peak +9 -> 261 MB; RAM: Avail +15 -> 4020 MB, Used +14 -> 419 MB, Peak +14 -> 420 MB
' 0:< GUI Resource Usage GDI: Avail 9826, Used 174, User: Used 206
' 0:< API_SUCCESS { Registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Starting External Application: RaaS, Class: Autodesk.RaaS.RevitAddin.EApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: RaaSApplication.dll }
'H 15-Mar-2019 12:45:52.261; 0:<
Jrn.Directive "IdleTimeTaskSymbol" _
, "0.ExternalEvent"
' 0:< API_SUCCESS { Starting External Application: AutoLoad, Class: AutoLoader.AutoLoader, Vendor : ADSK(), Assembly: AutoLoader.dll }
' 0:< API_SUCCESS { Registered an external server: Name(AutodeskDriveUI); VendorId(ADSK); ServerId(314de911-0991-4787-a0fd-914be9138034); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: ConnectedDesktopUI, Class: ConnectedDesktopUI.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ConnectedDesktopUI.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COORDINATION_MODEL' Executed implementation with implementation from application 'CoordinationModelUI' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\CoordinationModel\CoordinationModelUI.dll'. }
' 0:< API_SUCCESS { API registering command Coordination Model Executed event by application CoordinationModelUI (9817e4a5-0333-4323-b69e-781db5f70005). }
' 0:< API_SUCCESS { Replacing command id 'ID_COORDINATION_MODEL' CanExecute implementation with implementation from application 'CoordinationModelUI' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\CoordinationModel\CoordinationModelUI.dll'. }
' 0:< API_SUCCESS { API registering command Coordination Model CanExecute event by application CoordinationModelUI (9817e4a5-0333-4323-b69e-781db5f70005). }
' 0:< API_SUCCESS { Starting External Application: CoordinationModelUI, Class: Autodesk.CoordinationModelUI.CoordinationModelUIApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: CoordinationModelUI.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_CEA_OPTIMIZE' Executed implementation with implementation from application 'Energy Analysis' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\EnergyAnalysis\EnergyAnalysis.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Energy Analysis (f50a2212-f174-4890-84a9-064c3c835c4d). }
' 0:< API_SUCCESS { Replacing command id 'ID_CEA_OPTIMIZE' CanExecute implementation with implementation from application 'Energy Analysis' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\EnergyAnalysis\EnergyAnalysis.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Energy Analysis (f50a2212-f174-4890-84a9-064c3c835c4d). }
' 0:< API_SUCCESS { Starting External Application: Energy Analysis, Class: EnergyAnalysis.Application, Vendor : ADSK(), Assembly: EnergyAnalysis.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
'H 15-Mar-2019 12:45:52.851; 0:<
, "1.OnIdleTask"
' 0:< API_SUCCESS { Registering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Registering FabricationPartBrowserChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Replacing command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation with implementation from application 'FabPartBrowserApplication' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\FabricationPartBrowser\FabricationPartBrowser.dll'. }
' 0:< API_SUCCESS { API registering command Show Service in Part Browser
'Show Service in Part Browser
'Show Service in Part Browser CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Starting External Application: FabPartBrowserApplication, Class: FabricationPartBrowser.FabPartBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FabricationPartBrowser.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Duct not defined pressure drop UI server); VendorId(ADSK); ServerId(607992d7-359d-4593-b497-8aa238e2c564); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(9641a039-441e-42e2-93a6-c0e2177cc23c); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct specific loss pressure drop UI server); VendorId(ADSK); ServerId(d3b5e81d-9b8c-40da-8efb-99dd37fda611); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< API_SUCCESS { Registered an external server: Name(Duct coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(25fa8de2-67c4-47d1-91f6-bd6f0803a5ed); ServiceId(52009bda-c817-4aef-aa31-36dc3742516e) }
' 0:< ::0:: Delta VM: Avail -9 -> 134211916 MB, Used +3 -> 263 MB, Peak +3 -> 264 MB; RAM: Avail -11 -> 4010 MB, Used +5 -> 424 MB, Peak +5 -> 425 MB
' 0:< GUI Resource Usage GDI: Avail 9822, Used 178, User: Used 207
' 0:< API_SUCCESS { Registered an external server: Name(Pipe not defined pressure drop UI server); VendorId(ADSK); ServerId(62917391-e14d-4897-ad0c-05342d71e4f9); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific coefficient pressure drop UI server); VendorId(ADSK); ServerId(247265b6-7b71-4147-97c6-cc52b39c12aa); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe specific loss pressure drop UI server); VendorId(ADSK); ServerId(5978b92a-3f0b-4691-bbc8-caf2fae20a71); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Registered an external server: Name(Pipe K coefficient from table pressure drop UI server); VendorId(ADSK); ServerId(cda19b6f-fbd5-4725-a0ce-f159bf5d02fe); ServiceId(1931b323-1d29-4083-b1ce-bfdcddd011af) }
' 0:< API_SUCCESS { Starting External Application: FittingAndAccessoryCalculationUIServers, Class: FittingAndAccessoryCalculationUIServers.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: FittingAndAccessoryCalculationUIServers.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_EXPORT_IFC' Executed implementation with implementation from application 'IFC override' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\IFCExporterUI\IFCExportUI.dll'. }
' 0:< API_SUCCESS { API registering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< API_SUCCESS { Starting External Application: IFC override, Class: BIM.IFC.Export.UI.IFCCommandOverrideApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: IFCExportUI.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Revit Default UI Server.); VendorId(ADSK); ServerId(3ffc688a-bb2e-4145-90ab-9443da02aef6); ServiceId(1fe75ba7-79d4-45f6-8e31-c1b83d4476a9) }
' 0:< API_SUCCESS { Starting External Application: KeynoteUIServer, Class: KeynoteUIServer.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: KeynoteUIServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Internal Forces Server); VendorId(ADSK); ServerId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Starting External Application: Member Forces, Class: MemberForcesUI.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: MemberForces.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' Executed implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Replacing command id 'ID_NUMBERING_REINF_PARTITIONS' CanExecute implementation with implementation from application 'Object Numbering' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\ObjectNumbering\ObjectNumberingUI.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Object Numbering (32b5860a-aec9-4df7-96b0-07168b27446e). }
' 0:< API_SUCCESS { Starting External Application: Object Numbering, Class: BIM.Numbering.UI.NumberingUIApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: ObjectNumberingUI.dll }
' 0:< API_SUCCESS { Registered an external server: Name(PointCloudSnappingServer); VendorId(ADSK); ServerId(85f4b666-8811-4e3d-9ed4-3d2ae4cd2e4c); ServiceId(aaa05780-790c-43dc-bc41-1c2150227f45) }
' 0:< Third Party Updater 'PointCloudSnappingServer: Snapping Pipe Updater' registered for all documents.
' 0:< API_SUCCESS { Starting External Application: PointCloudSnappingServer, Class: PointCloudSnappingServer.Application, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PointCloudSnappingServer.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Duct Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report CanExecute event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { API registering command Pipe Pressure Loss Report Executed event by application PressureLossReport (b00d3753-d3bc-4255-9c97-e389de87a5d6). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_DUCT_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' CanExecute implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SELECT_PIPE_PRESSURE_LOSS_REPORT' Executed implementation with implementation from application 'PressureLossReport' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\MEPCalculation\PressureLossReport.dll'. }
' 0:< API_SUCCESS { Starting External Application: PressureLossReport, Class: PressureLossReport.PressureLossReportApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: PressureLossReport.dll }
' 0:< API_SUCCESS { Registered an external server: Name(Surface Distribution Server); VendorId(ADSK); ServerId(26046cb6-7954-47a3-ab4f-ee3a7e35a2ec); ServiceId(a2c22b44-c231-4d3f-b653-b81b6f8be150) }
' 0:< API_SUCCESS { Starting External Application: RebarUpdateApp, Class: RebarMorphedServer.RebarUpdateApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: RebarMorphedServer.dll }
' 0:< API_SUCCESS { Registered an external server: Name(SectionTypeParameterServer); VendorId(ADSK); ServerId(1b91ce46-ddb4-44ec-a942-d45efadde353); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Starting External Application: Structural Section Properties, Class: SectionProperties.ServerApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SectionProperties.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_FILE_TOPOSURFACE_CONVERT_TO_LINK' Executed implementation with implementation from application 'Site Linker Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SiteLinker\SiteLinker.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Site Linker Application (26af0fb8-0ceb-46dc-a0b1-79e0208edcdc). }
' 0:< API_SUCCESS { Replacing command id 'ID_FILE_TOPOSURFACE_CONVERT_TO_LINK' CanExecute implementation with implementation from application 'Site Linker Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SiteLinker\SiteLinker.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Site Linker Application (26af0fb8-0ceb-46dc-a0b1-79e0208edcdc). }
' 0:< API_SUCCESS { Starting External Application: Site Linker Application, Class: SiteLinker.SiteExportApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SiteLinker.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SPACE_NAMING_UTILITY' CanExecute implementation with implementation from application 'Space Naming Utility Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SpaceNaming\SpaceNaming.dll'. }
' 0:< API_SUCCESS { API registering command Space Naming Utility CanExecute event by application Space Naming Utility Application (02663093-563b-4e2f-b5be-5b75beb2e313). }
' 0:< API_SUCCESS { Replacing command id 'ID_MEP_SPACE_NAMING_UTILITY' Executed implementation with implementation from application 'Space Naming Utility Application' dll 'C:\Program Files\Autodesk\Revit 2018\AddIns\SpaceNaming\SpaceNaming.dll'. }
' 0:< API_SUCCESS { API registering command Space Naming Utility Executed event by application Space Naming Utility Application (02663093-563b-4e2f-b5be-5b75beb2e313). }
' 0:< API_SUCCESS { Starting External Application: Space Naming Utility Application, Class: SpaceNaming.Command, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: SpaceNaming.dll }
' 0:< ::0:: Delta VM: Avail -3 -> 134211914 MB, Used +1 -> 265 MB, Peak +1 -> 265 MB; RAM: Avail -15 -> 3995 MB, Used +2 -> 426 MB, Peak +2 -> 427 MB
' 0:< API_SUCCESS { Added pushbutton Id: 6400, name: , text: Batch Print, class: Revit.PrintHarness.PrintHarnessAPI, assembly: C:\Program Files\Autodesk\Batch Print for Revit 2018\BatchPrint.dll }
' 0:< API_SUCCESS { Starting External Application: Batch Print Application, Class: Revit.PrintHarness.PrintHarnessApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Batch Print for Revit 2018\BatchPrint.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Collaborate CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' Executed implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_360' CanExecute implementation with implementation from application 'Collaborate' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering WorksharedOperationProgressChanged event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentOpening event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering LinkedResourceOpening event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< API_SUCCESS { Registering LinkedResourceOpened event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< ::0:: Delta VM: Avail -1 -> 134211913 MB, Used +1 -> 267 MB, Peak +2 -> 267 MB; RAM: Avail -24 -> 3972 MB, Used +2 -> 429 MB, Peak +2 -> 429 MB
' 0:< API_SUCCESS { Starting External Application: Collaborate, Class: Autodesk.Revit.UI.Collaborate.CollaborateApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\Collaborate.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' Executed implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command BIM 360 Projects Executed event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Replacing command id 'ID_COLLABORATE_BROWSER' CanExecute implementation with implementation from application 'CollaborateBrowser' dll 'C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateBrowser.dll'. }
' 0:< API_SUCCESS { API registering command BIM 360 Projects CanExecute event by application CollaborateBrowser (901c7e33-857c-4c9c-846c-8f971c7cf72a). }
' 0:< API_SUCCESS { Starting External Application: CollaborateBrowser, Class: Autodesk.Revit.UI.CollaborateBrowser.CollaborateBrowserApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\CollaborateBrowser.dll }
'C 15-Mar-2019 12:45:54.637; 0:< SkyscraperClientHost: UpiConfig: C:\Program Files\Autodesk\Collaboration for Revit 2018\UPI\upiconfig.xml
'C 15-Mar-2019 12:45:54.702; 0:< SkyscraperClientHost: Initialize Success: True
' 0:< API_SUCCESS { Starting External Application: SkyscraperClientHostApplication, Class: SkyscraperClientHost.SkyscraperClientHostApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\Collaboration for Revit 2018\SkyscraperClientHost.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6401, name: , text: Transmit a model, class: eTransmitForRevit.eTransmitCommand, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6402, name: , text: Help, class: eTransmitForRevit.eTransmitHelp, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6403, name: , text: About, class: eTransmitForRevit.eTransmitAbout, assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Starting External Application: eTransmit for Revit, Class: eTransmitForRevit.eTransmitApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\eTransmit for Revit 2018\eTransmitForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6404, name: , text: Check, class: BIMStandardsManager.Command, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6405, name: , text: Manage, class: BIMStandardsManager.CommandConfig, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6406, name: , text: View, class: BIMStandardsManager.CommandReview, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6407, name: , text: About..., class: BIMStandardsManager.CommandAbout, assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Starting External Application: Model Review, Class: BIMStandardsManager.ExternalApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Model Review Events (1469753f-186d-4dc2-b0e9-431b302e62f9). }
' 0:< API_ERROR { Starting External Application: Model Review Events, Class: BIMStandardsManager.CommandEventsApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Revit Model Review 2018\ModelReview.dll }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Worksharing Monitor Application (04e9bc6c-9b81-4c82-a31a-7559fe7a1579). }
' 0:< ::0:: Delta VM: Avail -40 -> 134211873 MB, Used +1 -> 268 MB, Peak +0 -> 268 MB; RAM: Avail -8 -> 3964 MB, Used +4 -> 433 MB, Peak +3 -> 433 MB
' 0:< GUI Resource Usage GDI: Avail 9810, Used 190, User: Used 215
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Application, Class: WorkSharingLib.ExternalApplication, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\WorkSharingLib.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6408, name: , text: Launch WSM, class: WorksharingCommand.WorksharingCommand, assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Starting External Application: Worksharing Monitor Launch App, Class: WorksharingCommand.WorksharingApp, Vendor : ADSK(Autodesk, subscription.autodesk.com), Assembly: C:\Program Files\Autodesk\Worksharing Monitor for Revit 2018\WorkSharingCommand.dll }
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' Executed implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Replacing command id 'ID_TEAM' CanExecute implementation with implementation from application 'Communicator for Autodesk Revit' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\Communicator\SmartMonkey.dll'. }
' 0:< API_SUCCESS { API registering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Starting External Application: Communicator for Autodesk Revit, Class: Autodesk.Revit.SmartMonkeyPlugin.SmartMonkeyApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: Communicator\SmartMonkey.dll }
' 0:< API_SUCCESS { Registering Idling event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ViewActivating event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.3\Revit_2018\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo
'Dynamo CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
'Dynamo BeforeExecuted event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_VISUAL_PROGRAMMING_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.3\Revit_2018\DynamoRevitVersionSelector.dll'. }
'Dynamo Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< Third Party Updater 'Dynamo For Revit: Sun and Shadow Settings Updater' registered for all documents.
' 0:< API_SUCCESS { Registering DocumentChanged event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_PLAYLIST_DYNAMO' CanExecute implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.3\Revit_2018\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo Playlist CanExecute event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Replacing command id 'ID_PLAYLIST_DYNAMO' Executed implementation with implementation from application 'Dynamo For Revit' dll 'C:\Program Files\Dynamo\Dynamo Revit\1.3\Revit_2018\DynamoRevitVersionSelector.dll'. }
' 0:< API_SUCCESS { API registering command Launch Dynamo Playlist Executed event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Registering ApplicationClosing event by application Dynamo For Revit (8d83c886-b739-4acd-a9db-1bc78f315b2b). }
' 0:< API_SUCCESS { Starting External Application: Dynamo For Revit, Class: Dynamo.Applications.VersionLoader, Vendor : ADSK(Dynamo), Assembly: C:\Program Files\Dynamo\Dynamo Revit\1.3\Revit_2018\DynamoRevitVersionSelector.dll }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' Executed implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Publish Settings Executed event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Replacing command id 'ID_VIEWS_FOR_A360' CanExecute implementation with implementation from application 'Views For A360' dll 'C:\ProgramData\Autodesk\Revit\Addins\2018\.\ExportViewSelectorAddin\ExportViewSelectorAddin.dll'. }
' 0:< API_SUCCESS { API registering command Publish Settings CanExecute event by application Views For A360 (78bd1446-1817-4842-8075-591b0424acaa). }
' 0:< API_SUCCESS { Starting External Application: Views For A360, Class: Autodesk.Revit.Addin.ExportViewSelector.ExportViewSelectorApp, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: .\ExportViewSelectorAddin\ExportViewSelectorAddin.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6409, name: , text: Convert RFA
'to FormIt, class: RFAToAXMAddon.RFAToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6410, name: , text: Convert SKP
'to FormIt, class: RFAToAXMAddon.SketchUpToAXMCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\RFAToAXMAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6411, name: , text: Import FormIt
'to RVT, class: AXMImportorAddon.AXMImportorCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6412, name: , text: Reload Families, class: AXMImportorAddon.ReloadFamiliesCommand, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\AXMImportorAddon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6413, name: , text: About FormIt, class: FormItConverter.FormItLink, assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\FormItConverterRibbon.dll }
' 0:< ::0:: Delta VM: Avail -12 -> 134211862 MB, Used +13 -> 282 MB, Peak +15 -> 284 MB; RAM: Avail -15 -> 3950 MB, Used +14 -> 447 MB, Peak +15 -> 448 MB
' 0:< GUI Resource Usage GDI: Avail 9808, Used 192, User: Used 216
' 0:< API_SUCCESS { Starting External Application: FormIt Conversion, Class: FormItConverter.Ribbon, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\Program Files\Autodesk\FormIt Converter For Revit 2018\FormItConversionAddon\FormItConverterRibbon.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6414, name: , text: Lumion, class: RevitExporter.CommandAbout, assembly: C:\ProgramData\Autodesk\ApplicationPlugins\LumionLiveSync.bundle\Contents\2018\LumionPluginForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6415, name: , text: Start, class: RevitExporter.CommandLiveStart, assembly: C:\ProgramData\Autodesk\ApplicationPlugins\LumionLiveSync.bundle\Contents\2018\LumionPluginForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6416, name: , text: Stop, class: RevitExporter.CommandLiveStop, assembly: C:\ProgramData\Autodesk\ApplicationPlugins\LumionLiveSync.bundle\Contents\2018\LumionPluginForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6417, name: , text: Camera Sync, class: RevitExporter.CommandLiveCameraSync, assembly: C:\ProgramData\Autodesk\ApplicationPlugins\LumionLiveSync.bundle\Contents\2018\LumionPluginForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6418, name: , text: Status, class: RevitExporter.CommandBase, assembly: C:\ProgramData\Autodesk\ApplicationPlugins\LumionLiveSync.bundle\Contents\2018\LumionPluginForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6419, name: , text: Settings, class: RevitExporter.CommandLiveSettings, assembly: C:\ProgramData\Autodesk\ApplicationPlugins\LumionLiveSync.bundle\Contents\2018\LumionPluginForRevit.dll }
' 0:< API_SUCCESS { Added pushbutton Id: 6420, name: , text: Save File, class: RevitExporter.CommandExport, assembly: C:\ProgramData\Autodesk\ApplicationPlugins\LumionLiveSync.bundle\Contents\2018\LumionPluginForRevit.dll }
' 0:< API_SUCCESS { Registering ViewActivated event by application Revit To Lumion Bridge (968c26fd-c5d2-49d0-af10-5106ff036cfa). }
' 0:< API_SUCCESS { Registering Idling event by application Revit To Lumion Bridge (968c26fd-c5d2-49d0-af10-5106ff036cfa). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Revit To Lumion Bridge (968c26fd-c5d2-49d0-af10-5106ff036cfa). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Revit To Lumion Bridge (968c26fd-c5d2-49d0-af10-5106ff036cfa). }
' 0:< API_SUCCESS { Starting External Application: Revit To Lumion Bridge, Class: RevitExporter.LumionPlugin, Vendor : Act3(Lumion3D, http://Lumion3D.com), Assembly: LumionPluginForRevit.dll }
' 0:< ::0:: Delta VM: Avail -11 -> 134211851 MB, Used +2 -> 284 MB, Peak +1 -> 285 MB; RAM: Avail -8 -> 3942 MB, Used +3 -> 451 MB, Peak +2 -> 451 MB
' 0:< GUI Resource Usage GDI: Avail 9794, Used 206, User: Used 216
' 0:< API_SUCCESS { Added pushbutton Id: 6421, name: , text: Sefaira, class: SefairaRevit.ShowMainWindow, assembly: C:\Users\Michael\AppData\Local\Temp\Sefaira\revit-70a75cb1-5118-45e9-871d-0a29be386c77\SefairaRevit.dll }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Sefaira for Revit (f2e7256d-4fb8-411d-a3c6-14749a466a87). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Sefaira for Revit (f2e7256d-4fb8-411d-a3c6-14749a466a87). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Sefaira for Revit (f2e7256d-4fb8-411d-a3c6-14749a466a87). }
' 0:< API_SUCCESS { Registering ViewActivated event by application Sefaira for Revit (f2e7256d-4fb8-411d-a3c6-14749a466a87). }
' 0:< API_SUCCESS { Starting External Application: Sefaira for Revit, Class: SefairaBootstrap.App, Vendor : SEF(Sefaira, http://www.sefaira.com), Assembly: SefairaRevitBootstrap.dll }
' 0:< ::0:: Delta VM: Avail -3 -> 134211848 MB, Used +5 -> 290 MB, Peak +5 -> 291 MB; RAM: Avail -2 -> 3940 MB, Used +9 -> 461 MB, Peak +10 -> 462 MB
'C 15-Mar-2019 12:45:59.419; 0:< ->processShellCommand
'E 15-Mar-2019 12:45:59.419; 0:<
Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -17 -> 134211832 MB, Used 290 MB; RAM: Avail -11 -> 3930 MB, Used +2 -> 463 MB, Peak +1 -> 463 MB
' 0:< GUI Resource Usage GDI: Avail 9783, Used 217, User: Used 226
'C 15-Mar-2019 12:46:00.154; 0:< <-processShellCommand
'C 15-Mar-2019 12:46:00.154; 0:< ->DesktopMFCApp::doStartupWarnings
'C 15-Mar-2019 12:46:00.154; 0:< License readyForUI
'C 15-Mar-2019 12:46:00.311; 0:< manage debug modes
'C 15-Mar-2019 12:46:00.311; 0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< START CanUseHardware(forced)
' 1:<
'OGS Device Memory Size: 10174 MB
' 1:< ::1:: Delta VM: Avail -32940 -> 134178892 MB, Used +38 -> 328 MB, Peak +38 -> 329 MB; RAM: Avail -4 -> 3927 MB, Used +29 -> 493 MB, Peak +29 -> 493 MB
' 1:< GUI Resource Usage GDI: Avail 9782, Used 218, User: Used 238
' 1:< DX Device: DirectX 11, Hardware
' 1:< ::1:: Delta VM: Avail -12 -> 134178881 MB, Used 328 MB, Peak +0 -> 330 MB; RAM: Avail -7 -> 3920 MB, Used +1 -> 494 MB, Peak +3 -> 496 MB
' 1:< GUI Resource Usage GDI: Avail 9782, Used 218, User: Used 240
' 1:< DX Device: DirectX 11, WARP
'C 15-Mar-2019 12:46:01.475; 1:< START video card certification
' 1:< ::1:: Delta VM: Avail -18 -> 134178864 MB, Used +2 -> 331 MB, Peak +3 -> 333 MB; RAM: Avail +0 -> 3921 MB, Used +2 -> 497 MB, Peak +3 -> 500 MB
' 1:<
'Current driver version: 15.201.1101.0
'Certified driver(s):
' 1:< VIDEO CARD ENVIRONMENT: CARD="AMD Radeon R7 M270" ManufacturerID="1002" DeviceID="6604" osID="8000" DRIVER="15.201.1101.0" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 15-Mar-2019 12:46:01.533; 1:< FINISH video card certification
' 1.222587 1:<<<CanUseHardware(forced)
' 0:<
'Can use hardware=y
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=n
'DrvNewerThanTested=n
'CardIsNotListed=y
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 15-Mar-2019 12:46:01.534; 0:< MFCApp::testMSAA
'C 15-Mar-2019 12:46:01.534; 0:< postConditionalWarnings
'C 15-Mar-2019 12:46:01.550; 0:< giveAtomRegistrationWarnings
'C 15-Mar-2019 12:46:01.550; 0:< warnings->consumeAll
'C 15-Mar-2019 12:46:01.586; 0:< Process result of DebugModes-Changed Task Dialog
'C 15-Mar-2019 12:46:01.586; 0:< isMaterialLibraryAvailable
'C 15-Mar-2019 12:46:01.587; 0:< start up warnings for AddIns
'C 15-Mar-2019 12:46:01.588; 0:< <-DesktopMFCApp::doStartupWarnings
'C 15-Mar-2019 12:46:01.590; 0:< <-desktop InitNativeInstance
'C 15-Mar-2019 12:46:01.590; 0:< ->desktop InitManagedInstance
' 1:< API_SUCCESS { Registered an external server: Name(Site Linker); VendorId(ADSK); ServerId(c6c190c2-458e-48ea-ba79-722f26a87b45); ServiceId(c9979a42-11ab-4c25-93e1-abfb50b7be60) }
' 1:< API_SUCCESS { Registering ViewActivated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 1:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
'C 15-Mar-2019 12:46:01.810; 0:< <-desktop InitManagedInstance
' 0:< ::1:: Delta VM: Avail -55 -> 134178810 MB, Used +14 -> 345 MB, Peak +11 -> 345 MB; RAM: Avail -51 -> 3870 MB, Used +52 -> 549 MB, Peak +75 -> 575 MB
' 0:< GUI Resource Usage GDI: Avail 9761, Used 239, User: Used 243
'C 15-Mar-2019 12:46:03.459; 0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:< BuildNumber : 17134
' 0:< BuildType : Multiprocessor Free
' 0:< Caption : Microsoft Windows 10 Home
' 0:< CodeSet : 1252
' 0:< CountryCode : 1
' 0:< FreePhysicalMemory : 3964432
' 0:< FreeSpaceInPagingFiles : 9381196
' 0:< FreeVirtualMemory : 11176924
' 0:< MaxProcessMemorySize : 137438953344
' 0:< OSLanguage : 1033
' 0:< OSType : 18
' 0:< ServicePackMajorVersion : 0
' 0:< ServicePackMinorVersion : 0
' 0:< TotalVirtualMemorySize : 22018100
' 0:< TotalVisibleMemorySize : 12492480
' 0:< Version : 10.0.17134
' 0:< Process affinity mask : F
' 0:< System affinity mask : F
' 0:< PROCESSOR INFORMATION:
' 0:< AddressWidth : 64
' 0:< Architecture : 9
' 0:< Availability : 3
' 0:< Caption : Intel64 Family 6 Model 61 Stepping 4
' 0:< CurrentClockSpeed : 2401
' 0:< DataWidth : 64
' 0:< Description : Intel64 Family 6 Model 61 Stepping 4
' 0:< Family : 198
' 0:< L2CacheSize : 256
' 0:< Level : 6
' 0:< Manufacturer : GenuineIntel
' 0:< MaxClockSpeed : 2401
' 0:< Name : Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz
' 0:< ProcessorType : 3
' 0:< Revision : 15620
' 0:< Role : CPU
' 0:< SocketDesignation : SOCKET 0
' 0:< StatusInfo : 3
' 0:< Version :
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:< AdapterCompatibility : Advanced Micro Devices, Inc.
' 0:< AdapterDACType : Internal DAC(400MHz)
' 0:< AdapterRAM : -1048576
' 0:< Caption : AMD Radeon R7 M270
' 0:< Description : AMD Radeon R7 M270
' 0:< DriverDate : 20150806000000.000000-000
' 0:< DriverVersion : 15.201.1101.0
' 0:< Monochrome : 0
' 0:< Name : AMD Radeon R7 M270
' 0:< VideoArchitecture : 5
' 0:< VideoMemoryType : 2
' 0:< VideoProcessor : AMD Radeon Graphics Processor (0x6604)
' 0:< AdapterCompatibility : Intel Corporation
' 0:< AdapterRAM : 1073741824
' 0:< Caption : Intel(R) HD Graphics 5500
' 0:< CurrentBitsPerPixel : 32
' 0:< CurrentHorizontalResolution : 3840
' 0:< CurrentNumberOfColors : 4294967296
' 0:< CurrentRefreshRate : 60
' 0:< CurrentVerticalResolution : 2160
' 0:< Description : Intel(R) HD Graphics 5500
' 0:< DriverDate : 20160929000000.000000-000
' 0:< DriverVersion : 20.19.15.4531
' 0:< MaxRefreshRate : 60
' 0:< MinRefreshRate : 47
' 0:< Name : Intel(R) HD Graphics 5500
' 0:< VideoModeDescription : 3840 x 2160 x 4294967296 colors
' 0:< VideoProcessor : Intel(R) HD Graphics Family
' 0:< PRINTER INFORMATION:
' 0:< Caption : Send To OneNote 2016
' 0:< Default : 0
' 0:< DeviceID : Send To OneNote 2016
' 0:< Direct : 0
' 0:< DriverName : Send to Microsoft OneNote 16 Driver
' 0:< EnableBIDI : 0
' 0:< EnableDevQueryPrint : 0
' 0:< HorizontalResolution : 600
' 0:< Local : -1
' 0:< Name : Send To OneNote 2016
' 0:< Network : 0
' 0:< PortName : nul:
' 0:< PrintJobDataType : RAW
' 0:< PrintProcessor : winprint
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< SpoolEnabled : -1
' 0:< VerticalResolution : 600
' 0:< Caption : OneNote
' 0:< Default : 0
' 0:< DeviceID : OneNote
' 0:< Direct : 0
' 0:< DriverName : Microsoft Software Printer Driver
' 0:< HorizontalResolution : 300
' 0:< Local : -1
' 0:< Name : OneNote
' 0:< Network : 0
' 0:< PortName : Microsoft.Office.OneNote_16001.11328.20100.0_x64__8wekyb3d8bbwe_microsoft.onenoteim_S-1-5-21-2168699058-4169735016-2192660147-1001
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 300
' 0:< Caption : Microsoft XPS Document Writer
' 0:< Default : 0
' 0:< DeviceID : Microsoft XPS Document Writer
' 0:< Direct : 0
' 0:< DriverName : Microsoft XPS Document Writer v4
' 0:< Local : -1
' 0:< Name : Microsoft XPS Document Writer
' 0:< Network : 0
' 0:< PortName : PORTPROMPT:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Microsoft Print to PDF
' 0:< Default : 0
' 0:< DeviceID : Microsoft Print to PDF
' 0:< Direct : 0
' 0:< DriverName : Microsoft Print To PDF
' 0:< Local : -1
' 0:< Name : Microsoft Print to PDF
' 0:< Network : 0
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : HP8D473A (HP Photosmart D110 series)
' 0:< Default : 0
' 0:< DeviceID : HP8D473A (HP Photosmart D110 series)
' 0:< Direct : 0
' 0:< DriverName : HP Photosmart D110 series Class Driver
' 0:< Local : -1
' 0:< Name : HP8D473A (HP Photosmart D110 series)
' 0:< Network : 0
' 0:< PortName : WSD-4d311f33-aa07-4e72-b457-567a7db828ec.003f
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Fax
' 0:< Default : 0
' 0:< DeviceID : Fax
' 0:< Direct : 0
' 0:< DriverName : Microsoft Shared Fax Driver
' 0:< HorizontalResolution : 200
' 0:< Local : -1
' 0:< Name : Fax
' 0:< Network : 0
' 0:< PortName : SHRFAX:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 200
' 0:< Caption : CutePDF Writer
' 0:< Default : -1
' 0:< DeviceID : CutePDF Writer
' 0:< Direct : 0
' 0:< DriverName : CutePDF Writer v3.2
' 0:< Local : -1
' 0:< Name : CutePDF Writer
' 0:< Network : 0
' 0:< PortName : CPW3:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< Caption : Canon TS3100 series
' 0:< Default : 0
' 0:< DeviceID : Canon TS3100 series
' 0:< Direct : 0
' 0:< DriverName : Canon TS3100 series
' 0:< EnableBIDI : -1
' 0:< HorizontalResolution : -3
' 0:< Local : -1
' 0:< Name : Canon TS3100 series
' 0:< Network : 0
' 0:< PortName : WSD-cf5a4017-93a1-4d5e-a4f2-e276d05524ef.0062
' 0:< PrintProcessor : Canon TS3100 series Print Processor
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : -3
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Send To OneNote 2016
' 0:< DriverVersion : 1539
' 0:< Orientation : 1
' 0:< PaperLength : 2794
' 0:< PaperSize : Letter 8 1/2 x 11 in
' 0:< PaperWidth : 2159
' 0:< PrintQuality : 600
' 0:< SpecificationVersion : 1025
' 0:< XResolution : 600
' 0:< YResolution : 600
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : OneNote
' 0:< PrintQuality : 300
' 0:< XResolution : 300
' 0:< YResolution : 300
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft XPS Document Writer
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft Print to PDF
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : HP8D473A (HP Photosmart D110 series)
' 0:< Duplex : 0
' 0:< MediaType : 274
' 0:< Color : 1
' 0:< Description : Fax
' 0:< DriverVersion : 1024
' 0:< Duplex : 0
' 0:< PrintQuality : 200
' 0:< XResolution : 200
' 0:< YResolution : 200
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : CutePDF Writer
' 0:< PaperSize : UNKNOWN
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Canon TS3100 series
' 0:< DriverVersion : 3082
' 0:< Duplex : 0
' 0:< MediaType : 1
' 0:< PrintQuality : -3
' 0:< ::1:: Delta VM: Avail +40 -> 134178850 MB, Used 345 MB, Peak +2 -> 348 MB; RAM: Avail -201 -> 3669 MB, Used +1 -> 551 MB
' 0:< GUI Resource Usage GDI: Avail 9761, Used 239, User: Used 235
'E 15-Mar-2019 12:48:05.422; 0:<
Jrn.Command "SystemMenu" , "Quit the application; prompts to save projects , ID_APP_EXIT"
' 1:< ::2:: Delta VM: Avail +48 -> 134178898 MB, Used -8 -> 338 MB; RAM: Avail +194 -> 3864 MB, Used -38 -> 513 MB
' 1:< GUI Resource Usage GDI: Avail 9836, Used 164, User: Used 156
' 1:< Revit worker 1 closed cleanly
' 0:< [00001f24]QueueMinder stopped
'C 15-Mar-2019 12:48:10.295; 1:< logging finished virtualization services
'C 15-Mar-2019 12:48:10.295; 1:< logging finished worker services
'C 15-Mar-2019 12:48:10.298; 1:< logging erased queues
' 4.068029 1:<<<Terminating Slave Processes
'C 15-Mar-2019 12:48:10.300; 0:< ->desktop ExitManagedInstance
'C 15-Mar-2019 12:48:10.598; 0:< <-desktop ExitManagedInstance
'C 15-Mar-2019 12:48:10.598; 0:< ->desktop ExitNativeInstance
' 0:< API_SUCCESS { Unregistering ViewActivated event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentClosed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering DockableFrameVisibilityChanged event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Unregistering Idling event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings CanExecute event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_FABRICATION_SETTINGS' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Fabrication Settings Executed event by application FabPartBrowserApplication (ee72acb7-2d70-484e-9cdf-0f7006b1183e). }
' 0:< API_SUCCESS { Restoring command id 'ID_FABRICATION_PART_SHOW_SERVICE_IN_PART_BROWSER' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Show Service in Part Browser
' 0:< API_SUCCESS { Restoring command id 'ID_EXPORT_IFC' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Export to IAI IFC (Industry Foundation Classes) file format Executed event by application IFC override (e78da2e3-7e89-464c-97cd-2212c8be3fa8). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_SPACE_NAMING_UTILITY' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Space Naming Utility CanExecute event by application Space Naming Utility Application (02663093-563b-4e2f-b5be-5b75beb2e313). }
' 0:< API_SUCCESS { Restoring command id 'ID_MEP_SPACE_NAMING_UTILITY' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Space Naming Utility Executed event by application Space Naming Utility Application (02663093-563b-4e2f-b5be-5b75beb2e313). }
' 0:< API_SUCCESS { Unregistering ViewActivated event by application Collaborate (14f73f04-900e-4e24-8d85-44c71092b6e9). }
' 0:< ::2:: Delta VM: Avail -7 -> 134178892 MB, Used +1 -> 339 MB; RAM: Avail -12 -> 3853 MB, Used +1 -> 515 MB
' 0:< GUI Resource Usage GDI: Avail 9839, Used 161, User: Used 154
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' Executed implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator Executed event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Restoring command id 'ID_TEAM' CanExecute implementation. }
' 0:< API_SUCCESS { API unregistering command Communicator CanExecute event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentCreated event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSaved event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering ApplicationClosing event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizingWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizedWithCentral event by application Communicator for Autodesk Revit (a729345d-1c99-4ac0-91f2-28d93237fe14). }
' 0:< ::2:: Delta VM: Avail +4 -> 134178897 MB, Used -14 -> 325 MB; RAM: Avail +6 -> 3860 MB, Used -8 -> 508 MB
' 0:< GUI Resource Usage GDI: Avail 9839, Used 161, User: Used 153
' 0:< API_SUCCESS { Unregistering ViewActivated event by application Revit To Lumion Bridge (968c26fd-c5d2-49d0-af10-5106ff036cfa). }
' 0:< API_SUCCESS { Unregistering Idling event by application Revit To Lumion Bridge (968c26fd-c5d2-49d0-af10-5106ff036cfa). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application Revit To Lumion Bridge (968c26fd-c5d2-49d0-af10-5106ff036cfa). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application Revit To Lumion Bridge (968c26fd-c5d2-49d0-af10-5106ff036cfa). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Unregistering DocumentCreated event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application CoordinationModelDB (c9463641-1c02-431c-9502-4ad0c91de1ce). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application CollaborateDB (bb3086be-63bb-44bd-99eb-d584c013cf2f). }
' 0:< Forcibly unregistering Updater with id:51c0be9b-07a8-443a-be8c-21db815b17e7
' 0:< Forcibly unregistering Updater with id:649e613c-2d39-4a7b-9720-662750f5243e
' 0:< Forcibly unregistering Updater with id:84739e25-1013-4cbf-aa48-60c99ebf0415
' 0:< Forcibly removing all update triggers for all Updaters
' 0:< Unregistering all external services.
' 0:< ::2:: Delta VM: Avail +64 -> 134178962 MB, Used -27 -> 299 MB; RAM: Avail +1 -> 3862 MB, Used -13 -> 495 MB
' 0:< GUI Resource Usage GDI: Avail 9842, Used 158, User: Used 133
'C 15-Mar-2019 12:48:12.252; 0:< License cleanup complete: 0, 0
' 0:< Journal Exit
'C 15-Mar-2019 12:48:12.306; 0:< Log Summary
' 0:< .Count
' 0:< ...PendingMessages = 81
' 0:< ...WorkerRequestHandledImmediate = 3
' 0:< BC: 0,0,0
' 0:< Total session time spent reclaiming memory: 0.000000 seconds. Averaged 0.000000 seconds/call for 0 calls.
' 0:< BackgroundLoader exec= 1 (parallel= 1)
' 0:< FormOrAbandon exec= 1 (parallel= 0) self= 0.018778 sec (avg= 0.019)
' 0:< InstrumentationTask exec= 1 (parallel= 1)
' 0:< QueueMinder exec= 1 (parallel= 1)
' 0:< TaskFileExists exec= 339 (parallel= 332)
' 0:< TaskWaitCursor exec= 1 (parallel= 1)
' 0:< ::2:: Delta VM: Avail +32 -> 134178994 MB, Used -5 -> 294 MB; RAM: Avail +53 -> 3915 MB, Used -11 -> 485 MB
' 0:< GUI Resource Usage GDI: Avail 9842, Used 158, User: Used 123
'C 15-Mar-2019 12:48:12.714; 0:< <-desktop ExitNativeInstance
' 0:< ::2:: Delta VM: Avail +15 -> 134179009 MB, Used 294 MB; RAM: Avail +0 -> 3916 MB, Used -2 -> 483 MB
' 0:< GUI Resource Usage GDI: Avail 9843, Used 157, User: Used 121
'C 15-Mar-2019 12:48:12.724; 0:< finished recording journal file
This is the latest journal. I've tried to launch it multiple times after that time stamp. No existing journal exists.
